I am soon getting a dvd player that plays divx and divx ultra. Will I just be able to burn divx files straight to a dvd-r and watch them on my player. If I add .srt files with the same name as the video will I be able to see the subs? Thanks
Yes, if your files are Divx compatible to your player. Just burn the files as a data disc. This info from Jman98 outlines what doesn't usually work with most Divx players:
Also, VBR audio might cause problems with some players, as well. If your AVIs have any of the above, you might need to modify/recompress them before they'll play on your player. SRT subs are just put in the same folder as the video and should play automatically, depending on your player settings.Originally Posted by jman98
I should add that programs like AutoGK and others encode Divx files that are compatible. Most Divx video off the net is also compatible, but you may find a few bad encodes.
BTW, What player did you get? I just picked up a $37US Philips 3960 from Walmart. I haven't tried it with any Divx files, but it plays DVDs well enough.
Thanks for the info. By the way whats with TDA3 doing a full recompress when the files are already divx? I tried using Avi FourCC Code Changer to change the fourcc as suggested here but no luck, https://forum.videohelp.com/topic354198.html?highlight=tmpgenc%20divx ........ And why is it that when I add a 100MB divx file to my TDA3 project, it takes up almost 200MB on the capacity indicator at the bottom of the screen?...........By the way, I went with the Philips DVP5140. It was on sale at Target for US $39.99.
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 10:11 -
Reconverting Divx videos to smaller Divx files.. strange resolution
By arcooke in forum Video ConversionReplies: 2Last Post: 19th Jul 2011, 03:35 -
Beta Announcement: DivX Plus Web Player 2.1, DivX HiQ and HTML5 Support
By porfitron in forum Latest Video NewsReplies: 1Last Post: 23rd Nov 2010, 13:20 -
Philips DCP850 DivX overall quality (and DivX subtitle handling) question!
By mabhz in forum DVD & Blu-ray PlayersReplies: 0Last Post: 3rd Jul 2008, 19:59 -
Make an unplayable Xvid/Divx video play in a divx standalone Player
By AllenGorden in forum Newbie / General discussionsReplies: 4Last Post: 31st Dec 2007, 18:25
