I encode AVI videos and I often have parasites (as mosaic effets) on some pictures of my VCD file encoded using TMPGEnc. It doesn't appear all the time, i.e. if I try to encode the same file again it is possible that no default will appear, but it is a problem to have to encode the same file several times to be sure not to have a "corrupted" result. It seems to be an "encoding defalt", but is it due to my configuration or is it normal ? Sometimes there is just one block corrupted on 2 or 3 successive pictures of the video, and the result is a short break while reading the movie on a DVD player. Do you have solutions to resolve my problem ? Thanks.
Results 1 to 1 of 1
why does my subtitle appears pixelated in the movies??
By twinight in forum Video ConversionReplies: 16Last Post: 15th Dec 2010, 11:35 -
Video collage/mosaic effect
By purplegreendave in forum EditingReplies: 1Last Post: 9th Aug 2010, 04:06 -
video mosaic help.
By dbanga in forum Authoring (Blu-ray)Replies: 1Last Post: 1st Jul 2009, 06:32 -
Mosaic Looking Results
By treed68 in forum DVD RippingReplies: 5Last Post: 27th Jul 2008, 04:20 -
Sporadic Mosaic Pattern in FLV Conversion
By harley1387 in forum ffmpegX general discussionReplies: 0Last Post: 12th Jul 2007, 15:50
