iv got a DVD region hack i need to burn to cd and iv got no idea how to do it?? any ideas???![]()
Just use whatever CD burning software you have to burn it as a data CD.
"Just another sheep boy, duck call, swan
song, idiot son of donkey kong - Julian Cope" -
What is your purpose here? To save the hack to a disc for future reference? Because if you have the impression that you have to burn this to a disc to change the region on your DVD player, that probably won't work. Region codes are entered by remote controls. I suppose you might have some weird player where something is different, but it's definitely not normal to have to burn a CD to change the region.Originally Posted by Reprobate
You'll need some kind of CD burning software. Nero is incredibly easy to use, but not free. ImgBurn is free, but not easy to use for this kind of thing. -
To many DVD burner owners, Nero is free, because it comes as the accompanies burning software with the drive.Originally Posted by jman98
Not all players are hacked via the remote control. My LG DVB418, for example, requires a file burned to a data CD:
https://www.videohelp.com/dvdhacks?dvdplayer=dvb418&hits=50
-drjtechThey that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
--Benjamin Franklin -
iv got it sorted now, thanks for you advice. and jman98, my player is a sharp DV-740 and it did require a small .txt file to change to region.
DVD FLICK, Start-up Error Msg-Unable to created txt file. Last DLL error: 5
By jacknscoob in forum Authoring (DVD)Replies: 5Last Post: 4th Mar 2012, 09:58 -
Keeping subtitles in 2 lines from original .txt file in Subtitle Workshop
By Valerc in forum SubtitleReplies: 3Last Post: 10th Feb 2012, 07:45 -
IMporting to Subtitle Workshop from txt file
By kouim in forum SubtitleReplies: 4Last Post: 27th Jan 2011, 17:26 -
GSpot 2.70a - Export to .txt file
By skaleton in forum Newbie / General discussionsReplies: 0Last Post: 11th Nov 2010, 12:49 -
.txt file to .sup format
By pzoggy7 in forum SubtitleReplies: 5Last Post: 1st Jul 2008, 18:56
