Hi there, not sure if this is the right forum or not but I have what I think should bea simple question. I am trying to author some AVCHD discs to play in blu-ray players from some downloaded x.264 mkv files. I am having some trouble and I think my problem stems from the fact that the videos are in non-standard resolutions. What I want to be able to do is convert the video to something like true 720p or 1080p so the playback is will function properly in my blu-ray players. Is there any easy way to change the size of the video?
Results 1 to 10 of 10
I have a 1920x1080 AVCHD video that works perfectly on every blu ray player I have tried. What I am trying to do, is convert several videos I have download that have the .mkv file extension and use x.264, into a blu-ray compatible AVCHD disc. Problem is, whenever I convert the videos and burn them, they will only play in player ( BDP-1500) and when they do, the formatting is all messed. The image is squeezed in from the sides so that the image is in only about the middle third of the TV. So I assumed it was because of the non-standard resolutions the videos are in. By non-standard I mean 1280x536 or 1920x800, and many others than that.
Yes, that's at least 1 reason for your problems (there might be more)
You have to add borders in the avs script
e.g. if you had 1920x800,
addborders(0,140,0,140) -
In order to make it compliant, as in 1920x1080,use the 2nd # for your calculation..
e.g 1920x800
1080-800=280 , 280/2=140 borders needed to top and bottom to make it compliant..." Who needs Google, my wife knows everything" -
How do we add/change borders in the avs script please?Originally Posted by t0nee1Genii nor fools may work without tools!
He already told you that: AddBorders(0,140,0,140). For slightly better quality you want the borders to be integer multiples of 8. So AddBorders(0,136,0,144) will work even better.Originally Posted by Robertiebert
hi, i am haviing similar problem as i have a 1920x1040 file and its out of standard. so it seems i have to rezise it to 1920x1080. whats the quickest way to do it? i dont know much about avs script
Sound and video do not sync up when I convert avi to h.264 x 264.
By toddlava1 in forum ffmpegX general discussionReplies: 1Last Post: 8th Mar 2012, 02:15 -
Video Encoding Resize
By darkw1zard in forum EditingReplies: 7Last Post: 21st Oct 2011, 11:32 -
Resize video without converting
By JOHNINA in forum Video ConversionReplies: 6Last Post: 27th Feb 2010, 21:25 -
Can I crop and resize video?
By maldb in forum EditingReplies: 6Last Post: 13th Jun 2009, 19:06 -
Video Crop and resize
By quxote in forum EditingReplies: 4Last Post: 27th Feb 2009, 11:48
