iv imported some video that used to be divx but we changed it to avi.
when i render it the picture works fine but the audio doesnt play at all. all of the other audio in my project works perfectly except for these type of files.
see how in this picture http://www.harmony-central.com/articles/reviews/sony_vegas/fig1.gif down the bottom the audio track has two lines of audio on top of eachother - kinda looks like its mirrored. anyway, the audio that doesnt work has two lines, on the bottom line is the audo which u can see the waves, but the top line is just a flat line - ie there doesnt seem to be any audio there. is this the problem?
any ideas on what i can do to fix this?
Vegas doesn't like VBR MP3 audio. Chances are your Divx video has this. Vegas is not designed to edit video that hs been compressed using end viewing compression such as Divx and Xvid. While it can be forced to, the results are usually less than desirable. Convert your video to an editable format such as DV avi and you wont have these problems.
Read my blog here.
Sony Vegas Pro 10 - video/audio out of synch after render
By Acester47 in forum EditingReplies: 4Last Post: 1st Jul 2011, 15:06 -
Problem with importing audio from movie track - Sony Vegas Pro
By tooninoz in forum Newbie / General discussionsReplies: 0Last Post: 18th Nov 2010, 01:39 -
Importing multi-tracked audio (.ac3) into Sony Vegas Pro 9.0
By Thunderhead2772 in forum EditingReplies: 0Last Post: 28th Aug 2010, 19:10 -
Sony Vegas Pro 8.0 : Problem to encode audio file into mp3.
By flash_49 in forum Video ConversionReplies: 0Last Post: 20th Jul 2010, 07:21 -
Sony Vegas 8 Pro - No audio stream for MPEG-2 video
By tarrickb in forum Newbie / General discussionsReplies: 10Last Post: 9th Jan 2010, 16:45
il give it a shot
