I am having a LG DR197 DVD recorder, and a Humax Sat receiver. Problem is that the sat receiver only has a scart exit, how can I connect this to my LG so I can record from sattelite ?
Uh, according to a quick web search (eg. see "http://www.shopping.com/xPF-LG-DR197") , the LG DR197 has a SCART input, so all you need is a SCART cable.Originally Posted by nicewithice
It can also record from a RGB source, so an "RGB-enabled" SCART cable would give you the best possible recording quality (you may have to enable RGB output in your sat boxs Video/Display preferences screen). -
Thanks for the answer. Indeed, I could connect the scart cable to the hum, scart connection for a component. It works BUT...there is no sound. Also tried with the RGB cable, same result. Any other suggestions are welcome ! The strange thing is that A) I did it 1 year ago, but don't remember how and B) all programms say MONO.... and C) I did a test recording where the sound is also missing. However when I switch off the DVD recorder, the sound is back.
Hi,
you can try to use this device:
You plug it on the scart exit or your satellite receiver and then connect your tv and dvd recorder to the device like this. -
Thanks all, it works now. I did some research on the DVD recorder, it was setup on the wrong channel.... But thanks to this forum I solved it, and I also could make the player region free !!!!
connecting sattelite reciever box, tv, and dvd recorder.
By steve6 in forum MediaReplies: 4Last Post: 19th Feb 2011, 14:56 -
Hdd/dvd recorder receiver system LG LH3690se
By emihle0101 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 30th Aug 2010, 10:35 -
Newbie question, connecting speakers to A/V receiver
By mordeckai in forum Newbie / General discussionsReplies: 2Last Post: 13th Aug 2010, 18:31 -
connecting laptop to receiver help
By mr-scarface in forum AudioReplies: 3Last Post: 24th Sep 2008, 05:09 -
Connecting a Dutch LG DVD recorder to a American TV??
By Anna needs help in forum DVD & Blu-ray RecordersReplies: 6Last Post: 15th Aug 2008, 22:01
