Results 1 to 10 of 10
    Jul 2008
    A friend has given me several mini DVD's he recorded with his camera that he wants consolidated on a couple of DVD-R's with a menu. Easy job...right? Well...his camera records at 512 x 480, and when I convert the VOB files to MPEG and place in a timeline in Adobe Encore, all is well - except when I build. I get an error saying that the resolution isn't supported by DVD. Is there any way of making this work short of re-encoding the MPEG's to 720 x 480 or another legal resolution ?
    Thanks all,
    Steve
    Apr 2004
    Miskatonic U
    half-D1 is legal, but some of the older versions of Encore did not support it (in fact they would only support 720 x nnn). Either upgrade to a version that does support it, or if none do, use an authoring tool that actually observes fully the DVD specification. GUIForDVDAuthor is free, powerful and will accept your files.
    Read my blog here.
    Jul 2008
    I'm using Encore CS3. Guess I'll try the other app.
    Thanks!
    Apr 2004
    Miskatonic U
    Hang on a moment. I have just re-read your post, and 512 x 480 is not half-D1, or in fact DVD legal. Can you confirm that resolution using g-spot.
    Read my blog here.
  5. You could try the "patch" method to fool Encore into thinking the frame size is legal.
    Jul 2008
    Sorry, my error...Windows Media Player was reporting the size as 512 x 480, but g-spot shows it at 352 x 480. At any rate, Encore CS3 only accepts NTSC resolutions according to their Help section, so I'm re-encoding to that size.
    Jul 2008
    "patch" method? I'm not familiar, but willing to learn.
  8. Member FulciLives's Avatar
    May 2003
    Pittsburgh, PA in the USA
    Rather than re-encode ... just use a DVD authoring program that properly accepts Half D1 resolution.
    Half D1 resolution is DVD Video compliant. The problem is Adobe Encore.
    - John "FulciLives" Coleman
    Jul 2008
    Yep...I've figured that out. Any advice on a program that'll do that?
  10. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    GUIForDVDAuthor is free and very capable (wait - didn't I say that in my first post ?). Otherwise, pretty much anything else, from DVD Workshop to DVD Architect to DVD Lab Pro.
    Read my blog here.
