Hi, I have a MKV file from a movie and would like to convert it to a DVD. The source file is very high in quality (7Gb total) and contains multiple audio / subtitle tracks.
I found FAVC could do the job, but will it keep all the audio and subtitles tracks in the output DVD? If not, is there any way to make a direct conversion (MKV > DVD) and keep all the "extras"?
noOriginally Posted by TioSolid
you'll have to go manual, at least partly.
tripp"I'll give you five dollars if you let me throw a rock at you" -
DVDFlick and MkvExtractGui might be worth a try. I haven't tried both multiple audio tracks and subtitles, but DVDFlick has the ability to add both. First you would need to extract the subtitles and audio tracks you want with MkvExtractGui. In DVDFlick add the original MKV file to your project, then add the extracted subtitles and audio tracks using "edit title" on the right side of the project page. There is a built in help file with pictures to guide you.
Good luck. -
THanks very much for all the replies. Will check the DVD Flick tool when I arrive at home. It looks exaclty what I needOriginally Posted by note-2-tom
Well, it worked but the subtitles are a bit messy. When I should read "Can We Talk?" the .ass file says "Can We TaIk?"
Does anybody knows why? -
So that is an I rather than an l in 'talk'?
What font was used in the subs? Someone might have used an uppercase 'I' to make the letter stand out more in the original subtitles, based upon the font being used.If cameras add ten pounds, why would people want to eat them? -
TioSolid wrote:
Actually that .ass file was based on a .srt file which was OCR-generated.Well, it worked but the subtitles are a bit messy. When I should read "Can We Talk?" the .ass file says "Can We TaIk?"
And as we all know, cheapo OCR engines do suck.
P.S.: Your avatar is really annoying.
Yes, its an I (indian) instead of a l (lonely), but in the original subtitle (while watching the video) the sub is fine (no i instead of l).So that is an I rather than an l in 'talk'?
I thought about the same thing. Is there any way to force mkvextract to use a given font instead of its default one for OCR'ing ?Actually that .ass file was based on a .srt file which was OCR-generated.
And LOL about your comment of my avatar :P
How to remove one of two audio tracks in a mkv file?
By BooSnow in forum AudioReplies: 4Last Post: 18th Oct 2020, 10:00 -
Can do BDRebuilder a mkv file with more than one language tracks
By videoten in forum Blu-ray RippingReplies: 4Last Post: 4th Jun 2010, 14:39 -
No Audio On AVCHD-DVD, How To Remove Other Audio Tracks From MKV File First
By elistian in forum Video ConversionReplies: 1Last Post: 14th Dec 2009, 06:03 -
Audio tracks in MKV
By giosa in forum Software PlayingReplies: 2Last Post: 18th May 2009, 07:52 -
How to keep two audio tracks of DVD in MKV (x264)
By maass in forum DVD RippingReplies: 1Last Post: 20th Apr 2009, 10:36
