Hi, I have a few mkv files that are 1080p resolution. They do not work with HA using dxva.
I'm suing Media Player classic Homecinema.
Club 3D HD3850 AGP 512MB
P4.3 Ghz HT
3GB RAM
Win XP Pro SP3
I extracted the files using MKVextract but don't know how to recode them.
Tried to fix them using http://www.avsforum.com/avs-vb/showthread.php?t=972503 it does not work. So the only option is to recode them. I would like to get MP4 file that would work with DXVA.
Thank you.
File I need to FIX:
Code:[ About file ] Name: Evil.1080p.BluRay.x264.mkv Date: 23/07/2008 03:42:18 Size: 8,532,459,635 bytes (8137.188 MB) [ Generic infos ] Play duration: 01:33:49 (5628.64 s) Container type: matroska Creation time: 4/08/2007 14:52:16 UTC Number of streams: 2 Type of stream nr. 1: video (V_MPEG4/ISO/AVC) Type of stream nr. 2: audio (A_AC3) Audio streams: 1 Muxing Application: libebml v0.7.7 + libmatroska v0.8.1 Writing Application: mkvmerge v2.0.2 ('You're My Flame') built on Feb 21 2007 23:40:55 [ Relevant data ] Resolution: 1920 x 800 Width: multiple of 32 Height: multiple of 32 [ Video track ] Codec ID: V_MPEG4/ISO/AVC Resolution: 1920 x 800 Frame aspect ratio: 12:5 = 2.4 Pixel aspect ratio: 1:1 = 1 Display aspect ratio: 12:5 = 2.4 Framerate: 23.976024 fps [ Audio track ] Codec ID: A_AC3 Channels (container): 6 Sample rate: 48000 Hz Mode: 3 front, 2 rear, 1 LFE [ About H.264 encoding ] User data: x264 User data: core 56 svn-667C User data: H.264/MPEG-4 AVC codec User data: Copyleft 2005 User data: http://www.videolan.org/x264.html User data: cabac=1 User data: ref=5 User data: deblock=1:-2:-2 User data: analyse=0x3:0x133 User data: me=umh User data: subme=7 User data: brdo=1 User data: mixed_ref=1 User data: me_range=16 User data: chroma_me=1 User data: trellis=1 User data: 8x8dct=1 User data: cqm=0 User data: deadzone=21,11 User data: chroma_qp_offset=0 User data: threads=3 User data: nr=0 User data: decimate=1 User data: mbaff=0 User data: bframes=3 User data: b_pyramid=1 User data: b_adapt=1 User data: b_bias=0 User data: direct=3 User data: wpredb=1 User data: bime=1 User data: keyint=240 User data: keyint_min=24 User data: scenecut=40(pre) User data: rc=2pass User data: bitrate=11484 User data: ratetol=1.0 User data: rceq='blurCplx^(1-qComp)' User data: qcomp=0.60 User data: qpmin=10 User data: qpmax=51 User data: qpstep=4 User data: cplxblur=20.0 User data: qblur=0.5 User data: ip_ratio=1.40 User data: pb_ratio=1.30 SPS id: 0 Profile: High@L5.1 Num ref frames: 8 Chroma format idc: YUV 4:2:0 PPS id: 0 (SPS: 0) Entropy coding type: CABAC Weighted prediction: No Weighted bipred idc: B slices - implicit weighted prediction 8x8dct: Yes [ Profile compliancy ] Profile to check: MTK PAL 6000 Resolution: 1920 x 800 > 720 x 576 Framerate: 23.976024 <> 25 Warning: If you need a more complete report, then click on "DRF analysis"
Are there DXVA profiles ? I can't seem to find any?Originally Posted by guns1inger
Recoded the file and DXVA works however there seems to be quality drop?
File size is not 80mb but 37mb what did select wrong?
Code:[ About file ] Name: halcyon-res.1080p-sample.mp4 Date: 23/07/2008 12:49:54 Size: 39,531,985 bytes (37.701 MB) [ Generic infos ] Play duration: 00:01:02 (61.673333 s) Container type: MP4/MOV Major brand: ISO Base Media version 1 Compatible brands: JVT AVC Creation time: 22/07/2008 09:49:50 UTC Modification time: 22/07/2008 09:49:50 UTC Number of streams: 2 Type of stream nr. 1: video (avc1) {GPAC ISO Video Handler} Type of stream nr. 2: audio (AAC Low complexity) {GPAC ISO Audio Handler} Audio streams: 1 [ Relevant data ] Resolution: 1920 x 800 Width: multiple of 32 Height: multiple of 32 [ Video track ] Codec: avc1 Resolution: 1920 x 800 Frame aspect ratio: 12:5 = 2.4 Pixel aspect ratio: 1:1 = 1 Display aspect ratio: 12:5 = 2.4 Framerate: 23.976023 fps Number of frames: 1477 Bitrate: 4998.407198 kbps [ Audio track ] Codec: AAC Low complexity Bitrate: 131.575968 kbps Channels: 6 Sample rate: 48000 Hz [ About H.264 encoding ] User data: x264 User data: core 60 r891kVAQ2mod.PsyRDO-generic-pf 2ca4593 User data: H.264/MPEG-4 AVC codec User data: Copyleft 2003-2008 User data: http://www.videolan.org/x264.html User data: cabac=1 User data: ref=3 User data: deblock=1:0:0 User data: analyse=0x3:0x133 User data: me=umh User data: subme=6 User data: rdcmp=psy User data: brdo=1 User data: mixed_ref=1 User data: me_range=16 User data: chroma_me=1 User data: trellis=1 User data: 8x8dct=1 User data: cqm=0 User data: deadzone=21,11 User data: chroma_qp_offset=0 User data: threads=2 User data: nr=0 User data: decimate=1 User data: mbaff=0 User data: bframes=3 User data: b_pyramid=1 User data: b_adapt=1 User data: b_bias=0 User data: direct=1 User data: wpredb=1 User data: bime=1 User data: keyint=250 User data: keyint_min=25 User data: scenecut=40(pre) User data: rc=crf User data: crf=21.0 User data: rceq='blurCplx^(1-qComp)' User data: qcomp=0.60 User data: qpmin=10 User data: qpmax=51 User data: qpstep=4 User data: ip_ratio=1.40 User data: pb_ratio=1.30 User data: aq=3:3:0.60 SPS id: 0 Profile: High@L4.1 Num ref frames: 3 Aspect ratio: Square pixels Chroma format idc: YUV 4:2:0 PPS id: 0 (SPS: 0) Entropy coding type: CABAC Weighted prediction: No Weighted bipred idc: B slices - implicit weighted prediction 8x8dct: Yes [ Profile compliancy ] Profile to check: MTK PAL 6000 Resolution: 1920 x 800 > 720 x 576 Framerate: 23.976023 <> 25 Warning: If you need a more complete report, then click on "DRF analysis" -
You reduced the resolution from 1920x800 => 720x576
You will lose quality anyways because you've lost 3.7x the number of pixels from the resize! Furthermore you are using a lossy codec => more quality loss
You are using constant quality mode with CRF=21. If you want to reduce quality loss, try again with a lower setting such as 16-18 if the settings allow you to adjust them -
OK , encoded it with extreme preset changing only AVC level to 4.1,
Audio settings are:
ABR
AAC-LC
Bitrate 640
Configure tab:
48000Hz
Converter SSRC
Keep original channels
Input:
Codec: AC3
Codec ID: AC3
Bitrate: 640 kbps
Channels: 6 ch
Samplerate: 48000 Hz
Delay: 0 ms
Output:
Codec: AAC
Bitrate: 640 kbps
Channels: 6 ch
Delay: 0 ms
Amplifing: 0.0 dB
Original file size 83MBCode:[ About file ] Name: extreme res.evil2.1080p-sample.mp4 Date: 23/07/2008 19:19:31 Size: 73,495,080 bytes (70.09 MB) [ Generic infos ] Play duration: 00:01:02 (61.673333 s) Container type: MP4/MOV Major brand: ISO Base Media version 1 Compatible brands: JVT AVC Creation time: 22/07/2008 16:19:26 UTC Modification time: 22/07/2008 16:19:26 UTC Number of streams: 2 Type of stream nr. 1: video (avc1) {GPAC ISO Video Handler} Type of stream nr. 2: audio (AAC Low complexity) {GPAC ISO Audio Handler} Audio streams: 1 [ Relevant data ] Resolution: 1920 x 800 Width: multiple of 32 Height: multiple of 32 [ Video track ] Codec: avc1 Resolution: 1920 x 800 Frame aspect ratio: 12:5 = 2.4 Pixel aspect ratio: 1:1 = 1 Display aspect ratio: 12:5 = 2.4 Framerate: 23.976023 fps Number of frames: 1477 Bitrate: 8876.563912 kbps [ Audio track ] Codec: AAC Low complexity Bitrate: 663.797993 kbps Channels: 6 Sample rate: 48000 Hz [ About H.264 encoding ] User data: x264 User data: core 60 r891kVAQ2mod.PsyRDO-generic-pf 2ca4593 User data: H.264/MPEG-4 AVC codec User data: Copyleft 2003-2008 User data: http://www.videolan.org/x264.html User data: cabac=1 User data: ref=3 User data: deblock=1:-2:-1 User data: analyse=0x3:0x133 User data: me=umh User data: subme=7 User data: rdcmp=psy User data: brdo=1 User data: mixed_ref=1 User data: me_range=16 User data: chroma_me=1 User data: trellis=2 User data: 8x8dct=1 User data: cqm=0 User data: deadzone=21,11 User data: chroma_qp_offset=0 User data: threads=2 User data: nr=0 User data: decimate=0 User data: mbaff=0 User data: bframes=3 User data: b_pyramid=1 User data: b_adapt=1 User data: b_bias=0 User data: direct=1 User data: wpredb=1 User data: bime=1 User data: keyint=250 User data: keyint_min=25 User data: scenecut=40(pre) User data: rc=crf User data: crf=16.0 User data: rceq='blurCplx^(1-qComp)' User data: qcomp=0.60 User data: qpmin=10 User data: qpmax=51 User data: qpstep=4 User data: ip_ratio=1.40 User data: pb_ratio=1.30 User data: aq=3:3:0.60 SPS id: 0 Profile: High@L4.1 Num ref frames: 3 Aspect ratio: Square pixels Chroma format idc: YUV 4:2:0 PPS id: 0 (SPS: 0) Entropy coding type: CABAC Weighted prediction: No Weighted bipred idc: B slices - implicit weighted prediction 8x8dct: Yes [ Profile compliancy ] Profile to check: MTK PAL 6000 Resolution: 1920 x 800 > 720 x 576 Framerate: 23.976023 <> 25 Warning: If you need a more complete report, then click on "DRF analysis"
Re-coded 73MB
Any comments?
Many M2TS into ONE MKV HD (LOSSLESS, NO RECODE), how can i do ?
By tommydonnelly in forum Video ConversionReplies: 1Last Post: 5th May 2011, 15:08 -
Xmedia Recode Crashing when converting to MKV
By Des in forum DVD RippingReplies: 4Last Post: 30th Dec 2010, 10:37 -
Enabling DXVA when converting Blu-ray to mkv?
By ITISRAVI in forum Blu-ray RippingReplies: 3Last Post: 21st Sep 2010, 07:06 -
Lost DXVA with VC1 in MKV
By jameson_uk in forum Software PlayingReplies: 18Last Post: 8th Mar 2010, 19:08 -
virtualdubmod will not work with mkv file containing avc1 codec
By impmon2 in forum Video ConversionReplies: 5Last Post: 5th Nov 2009, 12:48
