Hi! I have a ton of old betamax format home movies which I want to convert to digital format. I bought the JVC GR-d93 for this purpose aside from the need of having a video camera for recording family events.
In any case the digital pass through function worked fine while capturing the video using firewire. However I noticed that the captured video from the betamax somehow flickers at a constant rate (every 5-10 seconds or so). It can be seen on the screen of the videocam. The flicker is at its worst after firewire capture in avi format in which the people or video "doubles" during this flicking moments. The movie shakes in these moments causing the figures to have multiple figures in a split second.
what seems to be the problem? Can this be solved? I have not tried VHS or other analog source at this point aside from betamax. thanks
Results 1 to 1 of 1
MP4Tools Pass thru sync issues
By bellevik in forum MacReplies: 2Last Post: 16th Apr 2012, 04:47 -
Canon HV40 analog/digital pass through?
By stantheman1976 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 30th Jun 2011, 07:23 -
8mm to Digital - Record to MiniDV vs Pass-through
By tripecac in forum Capturing and VCRReplies: 10Last Post: 1st Jul 2008, 17:46 -
JVC Mini-DV deck for DV Pass-Thru for capturing Live TV?
By Deisel Weisel in forum Capturing and VCRReplies: 1Last Post: 10th Jan 2008, 11:02 -
Will filters on my JVC SVHS model HR-S2901U work if used as pass-thru?
By theweight99 in forum RestorationReplies: 6Last Post: 7th Jun 2007, 22:21
