I get an error while loading my script into VirtualDubMod. It has to be something easy to fix? I will post both my script and the error.
Here is the error: AviSynth open failure: script error: there is no function named "RemoveDirt"
Here is my script below:
LoadPlugin("H:\Program Files\AviSynth 2.5\Plugins\removedirt.dll")
LoadPlugin("H:\Program Files\AviSynth 2.5\Plugins\removegrain.dll")
LoadPlugin("H:\Program Files\AviSynth 2.5\Plugins\msharpen.dll")
AVISource("I:\Apollo 13\video.avi")
RemoveGrain(mode=2)
RemoveGrain(mode=17)
RemoveDirt()
BlackmanResize(720,400)
MSharpen(10,100,true,false,false)
Results 1 to 12 of 12
It sure is there. I checked again now and I checked again earlier. It's name RemoveDirt.dll is the name just like that. Yes I have it.Originally Posted by poisondeathray
Are you sure it's the H: hard drive? Normal install is the C: hard drive
I was reading in the archieve at Doom9 but not sure if it's this issue but I had to import RemoveDirt.avs or change something to avsi but what do I change and how?
Yes I am sure. MS-DOS v6.22 is C and XP Pro is HOriginally Posted by poisondeathray
Not sure what you mean, or what you're saying; maybe ask at Doom9Originally Posted by rocky12
Can't my account is suppended for 30 days.Originally Posted by poisondeathray
http://forum.doom9.org/showthread.php?t=114517 (here is what I am talking about) -
Read the RemoveDirt.htm file. The latest RemoveDirt implements RemoveDirt() as an AVS script. You must create it (a sample is given in the htm file) an import it into your script.
RemoveDirt.AVS:
import("Path\to\RemoveDirt.avs")Code:function RemoveDirt(clip input, bool "_grey", int "repmode") { _grey=default(_grey, false) repmode=default(repmode, 16) clmode=17 clensed=Clense(input, grey=_grey, cache=4) sbegin = ForwardClense(input, grey=_grey, cache=-1) send = BackwardClense(input, grey=_grey, cache=-1) alt=Repair(SCSelect(input, sbegin, send, clensed, debug=true), input, mode=repmode, modeU = _grey ? -1 : repmode ) restore=Repair(clensed, input, mode=repmode, modeU = _grey ? -1 : repmode) corrected=RestoreMotionBlocks(clensed, restore, neighbour=input, alternative=alt, gmthreshold=70, dist=1, dmode=2, debug=false, noise=10, noisy=12, grey=_grey) return RemoveGrain(corrected, mode=clmode, modeU = _grey ? -1 : clmode ) } -
How do I create it? What file? Where is the file at?Originally Posted by jagabo
Create an AVS script called RemoveDirt.AVS with the code from my previous message. Put it in the same folder with all your other AviSynth plugins. Use the import line I gave (modified to use the correct path, the same as your LoadPlugins) in the AVS script that uses the function:
Import("H:\Program Files\AviSynth 2.5\Plugins\RemoveDirt.avs") # <-------------- note new line
RemoveGrain(mode=2)
RemoveDirt()
Can't open FLV with Avisynth
By Greensmurfet in forum Video ConversionReplies: 1Last Post: 21st Oct 2011, 18:00 -
AviSynth open failure in VirtualDub
By fatcharlie in forum Newbie / General discussionsReplies: 5Last Post: 3rd Mar 2011, 21:32 -
Avisynth question open failure FF3TdGPU.dll
By duster1234 in forum Video ConversionReplies: 4Last Post: 15th Oct 2008, 07:29 -
Avisynth open failure for cropping
By php111 in forum Newbie / General discussionsReplies: 51Last Post: 26th Mar 2008, 12:24 -
AVIsynth failure in VD
By php111 in forum Newbie / General discussionsReplies: 1Last Post: 1st Jan 2008, 04:08
