Try DVDFab and download streaming video, copy, convert or make Blu-rays,DVDs! Download free trial !
  1. Member Nuke Shower's Avatar
    Apr 2008
    I need a new movie editor and I am deciding between Sony Vegas 8 platinum and Final Cut Express. Do they both support MPEG-2?
    The only thing I hate about Vegas is it has HORRIBLE title making. The problem with Final Cut is my my mac is the less powerful white macbook so it might run slow. What should I choose?
    My camera is Sony's DCR-SR45
  2. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    More info needed. What sources are you editing and what results are you trying to achieve?
    Final Cut is designed for established pro work flows so the more you try to use it for typical consumer tasks, the more frustrated you will be with it. If you have a pro camcorder (DV or SDI best) and want to make a traditional commercial DVD or deliver an ad, promo or movie on tape, then you are in Final Cut territory.
    The Sony DCR-SR45 is a low end consumer MPeg2 camcorder. Vegas will load it from the file or DVD disc using the Import menu. FC will import it as a conventional MPeg2 file.
    Vegas Pro is centered in the Prosumer world with ability to move upmarket as needed. Sony formats (DV, AVCHD, IMX, HDV, XDCAM) are favored but you can edit JVC's 720p HDV and Panasonic's 24PA, DVCPro and DVCPro-HD as well but not their AVCHD without conversion.
    Vegas will not run on Mac OSX.
    http://www.kiva.org/about
  3. Member Nuke Shower's Avatar
    Apr 2008
    I know it wont, I have a PC two. I am talking about Final Cut Express. Not pro. I am also talking about Vegas Platinum. Not pro also.
  4. Member Soopafresh's Avatar
    Jan 2004
    Final Cut is OSX only
  5. Member edDV's Avatar
    Mar 2004
    What are your plans? Expecting to move to HD? What format?
    What kinds of editing?
    What tools will you be using?
    Try the demos, explore the features.
  6. Member Nuke Shower's Avatar
    Apr 2008
    I use allot of cool titles, color changes and correction, I rarely use fancy transitions besides fades. I make lots of movies with my friends (one has a Canon XL-2). We dont really post online much. We aren't beginners. We started out using WMM, then we used stuff like ulead/magix/pinnacle and all those kind of editors and we are going up a step in editors. We use Mac and Pc.
  7. Member edDV's Avatar
    Mar 2004
    I'm familiar with the pro versions of both products but not with what is missing in the "platinum" and "express" versions. Maybe others know these better. If you are working from DV source, either will work.
    Check out the features and tutorials at the respective web sites.
    http://www.apple.com/finalcutexpress/tutorials/
    http://www.sonycreativesoftware.com/moviestudiope
    This site has resources for Vegas
    http://www.blue7media.com/vegas/
    also
    http://www.vasst.com/training/tutorial%20link.htm
