I have and SD camcorder. I like the image quality but I was just wondering if there is any possible way to make SD look more like HD. If there is please tell me.
My camera is Sony's DCR-SR45
Its physically not possible, but if you are familiar or want to learn Avisynth, there is a function written by a user to try to achieve this. The Avisynth function is called iiP (or Integrated Image Processing). It is very slow at processing your video. It is like watching paint dry or grass grow. SLOOOOWWW. But the final output is pretty darn good. Not HD, but pretty good nonetheless.
If you dont have the time or patience, then I am not sure what else is out there.
Is your cam footage in widescreen format? Do you intend to to encode & burn to bluray or HD DVD format and watch on HDTV? Just curious. -
I really just want it to look better. It is Widescreen. I don't encode at all.
My camera is Sony's DCR-SR45 -
What do you mean by make it look more like HD?
You can't add resolution by upscaling. You can shoot at the highest bitrate allowed by the camcorder and in wide mode. That gets you the best SD picture that camera can export. Use the S-Video outputs to your HDTV. Your HDTV will upscale that to screen resolution.
Or convert to DVD at highest DVD bitrate and play from a DVD player using analog component or HDMI connections.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
The camcorder encodes everything to MPeg2. Set to highest quality in the menus.Originally Posted by Nuke ShowerRecommends: Kiva.org - Loans that change lives.
How do I make a menu?
By jbigfoot in forum Authoring (DVD)Replies: 3Last Post: 27th Feb 2008, 01:31 -
anyone knows how to make this (example)
By pike8 in forum EditingReplies: 6Last Post: 18th Feb 2008, 17:21 -
How do I make my Samsung R150 recorder region free? I have the code to make
By charpee in forum DVD & Blu-ray RecordersReplies: 2Last Post: 26th Jan 2008, 07:10 -
Make my PC into a Tivo?
By Xenogear900 in forum DVB / IPTVReplies: 5Last Post: 15th Nov 2007, 14:09 -
I want to make a DVD..
By Nyntendou in forum Authoring (DVD)Replies: 3Last Post: 26th Oct 2007, 12:33
