Hi,
This is really a general question about conversion. I have xilisoft video converter ultra. It is easy to use, but I have a very general question. It arises in the context of wanting to convert a MOV file to a different format but can equally apply to other files as well.
To begin: I have a MOV file that I would like to convert to either WMV, divX or mpeg 1. Why, because I would like to edit it, and don't want to use quicktime (a program I dislike immesely) and have other programs that can easily edit these other formats losslessly (ie solveig for WMV and avi; womble for mpeg). My question is what to convert it to in order to get best results in terms of not losing any more quality than is already lost in compressing the original file to MOV in the first place. I have experimented and converted the file to mpeg 1 an divX. To my eye the results seem about equal. In both cases the quality seems about the same (by converting at the high quality settings) to the original file. Is my eye seeing things correctly?
In other words what are the appropriate parameters to convert MOV files to another file format without losing further quality?
In general my question could be what is the rule of thumb in converting from one format to another (using programs like xilisoft) so as to minimize loss of video quality?
hopefully this question makes sense,
thanks
Use the latest virtualdub and the MOV plugin, and you can edit in virtualdub and output as Divx. Only one re-encode needed. However if you are happy with Xilisoft then quality obviously isn't the highest thing on your list.
Any time you use a lossy compression, you lose quality. Minimise by editing without re-encoding, or by using a lossless intermediate format. Lagarith or Huffyuv are well regarded for this purpose.Read my blog here.
Thanks guns1, but I would like to stick with xilisoft for the time being, realising that virtual dub is better.
So my question general qu remain; namely when using xilisoft-type conversion programs what would be the best thing to convert MOV files to out of divx, mpeg 1 or wmv? Or is it much of a muchness? -
OK, that is what I thought.
I certainly realise they are all lossy, but if I have MOV to begin with there is not much I can do other convert it to a format I prefer. -
How to convert FLV videos and resize them to convert them to AVI
By zikegi in forum Video ConversionReplies: 2Last Post: 18th Sep 2011, 00:06 -
Convert AVI (miniDV) to MKV/MP4, large files only convert partially
By Video Eddie in forum Video ConversionReplies: 0Last Post: 3rd Jan 2011, 06:44 -
To convert or not to convert a pal dvd
By nls8520 in forum Video ConversionReplies: 1Last Post: 22nd Jun 2010, 02:35
