Hi
I have read loads of tutorials but cannot find a simple answer to this question....
If I have a DVD that is for example 8GB including extras, the movie is only 3.5GB of that.
If I rip the whole disc, delete the vobs for the extras (leaving bups & ifos for everything including deleted vobs), if i use ifoedit to resequence the ifos, can i just burn what is left to a dvd-r ?
If yes, do i need to do the ifos in a certain order ?
If no is there a similar thing i could do to just get the movie ?
Thankyou, thankyou, thankyou !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!![]()
Hi Bob
One suggestion would be to use Cladmdec to rip the cd to your HD.
The reason being - in cladmec you can specify which pcg (program chain group) to rip, DVD's can often have multiple pcgs for example pcg0 might contain the main movie, pcg1 the trailers, pcg2 copyright warnings etc etc.
All you seem to need is just the main movie pcg.
One way to find which pcg you need is to check the time length which is written next to each pcg in the pcg menu list in cladmec.
Check how long the actual movie is then pick the matching pcg and rip it.
Might be and idea to check this site out http://clonead.cjb.net
hope this helps
xup
SOLID ANSWER: .Tivo to .MPG or MOV
By DarkPhoenix77 in forum MacReplies: 24Last Post: 5th Feb 2011, 16:43 -
what would the best setting for me for Handbrake ? plz answer
By FaisalKhan in forum Newbie / General discussionsReplies: 3Last Post: 4th Jan 2011, 08:38 -
can someone answer a general aspect ration question to me
By consumerx in forum Newbie / General discussionsReplies: 4Last Post: 1st Nov 2010, 10:58 -
Question closed. Reason: answer found elsewhere
By Hurdman in forum SubtitleReplies: 0Last Post: 9th Dec 2008, 02:54 -
Need someone who has seen Transformers The Movie(animated) to answer Q?
By Denvers Dawgs in forum Off topicReplies: 10Last Post: 27th Jun 2007, 20:42
