I have an .avi file that according to g.spot is encoded with the h.264 codec. Also, there is a subtitle file that is separate from the video file. What codec should I convert this file to in order to stream it to my ps3?
Thanks in advance
Thanks, I'll check it out.
Is it possible to just change the container to something else? I did that with some mkv files and would prefer to do it that way to avoid any image quality loss that comes with re-encoding the video. But I don't know if that's possible with avi files. -
Thanks, I'll check it out when I get home. But I'll still need to make the subtitle file permanent.
That means you MUST reencode.But I'll still need to make the subtitle file permanent.
Thanks for the info. Being able to stream to my ps3 seems to add another layer of complexity.
Sound and video do not sync up when I convert avi to h.264 x 264.
By toddlava1 in forum ffmpegX general discussionReplies: 1Last Post: 8th Mar 2012, 02:15 -
Blu-Ray to Mp4 x.264 1080p won't play on PS3
By Patrick_H in forum Media Center PC / MediaCentersReplies: 3Last Post: 31st Dec 2010, 10:53 -
Converting h.264 MKV to Play on PS3/Xbox360
By Startropic1 in forum Video ConversionReplies: 9Last Post: 29th May 2009, 00:34 -
mkv, x264, and h.264 to blu-ray to play on PS3
By cyberpimp16 in forum Authoring (Blu-ray)Replies: 1Last Post: 14th May 2009, 14:58 -
What is the best program to convert from H.264 mp4 to H.264 avi?
By Stealth3si in forum Video ConversionReplies: 6Last Post: 15th Sep 2007, 10:11
