Ok, I can't figure out this problem.
I have a Video_TS folder which when viewed on my computer displays in 16:9 but after I burn with Toast and play the DVD in my player it displays in 4:3.
I've looked in the copy options and preferences in Toast and there's no where to set the setting for aspect ratio.
Does anybody know how to correct this?
myDVDedit
make your dvd (toast or else, do not burn it, just create a folderwitrh your files authored for DVD)
in the finder, double-clic on an .IFO file (inside "VIDEO_TS" folder), it will open mydvdedit
in mydvdedit:
select your VTS (top left)
clic on the vertical button ccalled "VTS_xx" (middle bottom)
select aspect/display: set it to "16/9 letterbox and PanScan"
byeFor DVD, iPad, HD, connected TV, … iMovie & FCPX? MovieConverter-Studio 3 (01/24/2015) - Handle your camcorder's videos? even in 60p or 60i? do a slow-motion? MovieCam.
Changing aspect ratio of video files in iso so for burning w/ correct a/r
By cinesimon in forum Authoring (DVD)Replies: 6Last Post: 10th May 2011, 03:40 -
VOB2MPG - VIDEO_TS AND VTS_01_0 aspect ratio problem
By Joey9 in forum SVCD2DVD & VOB2MPGReplies: 7Last Post: 21st May 2010, 08:28 -
Video_TS folder has no menu(s) in Toast 10
By JonnyPhoenyx in forum MacReplies: 1Last Post: 8th Mar 2009, 16:02 -
changing aspect ratio of home video before burning
By bec in forum Authoring (DVD)Replies: 3Last Post: 8th Jul 2008, 13:54 -
VIDEO_TS (852x480) -> MPEG conversion: Aspect Ratio?
By jswayze in forum ffmpegX general discussionReplies: 7Last Post: 10th Jun 2007, 10:12
