I downloaded a Movie (avi) encoded with Divdx . I used VirtualDub to split the AVI so it would fit on a 80 min CD . I than used Nero 5.5 to make a Vcd . When I play that VCD on my tv. the picture is not sharp Is there any way to enhance the sharpness when played on a 32 inch TV. The AVI files are sharp when played on my computer.I have tried a few products to create the MPEG files to go on a VCD and have the same sharpness problems.
First of all, don't use plugin encoder with Nero. Try TMPG, which is the best mpeg1 encoder.
Secondly, if your avi source is encoded in high resolution and bitrate, convert it to SVCD instead of VCD to retain original quality. -
skyhawk--
DivX avi's that one downloads off of the internet use mpeg-4 data compression and are *highly* compressed. That means that the resulting file is not only exponentially smaller than the original DVD, but also contains exponentially less video and audio data than the orginal DVD. When you make a VCD, you are compressing an already compressed signal, which makes it look worse. I my experience, it is very difficult to make a VCD or SVCD that looks as good (or sharp) as the original DivX. Also consider the fact that most DivX's are at resolutions of 620x270 (or something similar). Standard VCD's only have a resolution of 352x240 for NTSC (north american TV), 352x288 for PAL (european). That's a big drop from your original file. I would recommend going the SVCD route, personally. They have a resolution of 480x480 (for NTSC), which should look a little bit better on your TV. The downside is that a compliant, standard SVCD only holds 35-40 minutes of video, so plan accordingly. Just keep in mind that garbage in means garbage out---if your original DivX file looks crappy, your SVCD or VCD will only look worse.
Screen Captured vidoes always lag when played back.
By techspark in forum Capturing and VCRReplies: 2Last Post: 27th Apr 2012, 18:50 -
StaxRip produces artifacts when played back in MPC
By Xavier in forum Video ConversionReplies: 7Last Post: 29th Oct 2010, 10:19 -
Overscan on DVD played back on a computer
By maeks84 in forum Authoring (DVD)Replies: 6Last Post: 21st Feb 2008, 08:02 -
Erros at and of DVDs when played back
By ronknights in forum Newbie / General discussionsReplies: 5Last Post: 6th Feb 2008, 11:18 -
DVD sound is terrible played back on stand alone players
By nikoz in forum Capturing and VCRReplies: 0Last Post: 12th May 2007, 18:13
