Hi All,
I have an old Miro DC30 capture card that I have used for hardware mjpeg capturing.
Now I am trying to set it up so I can use the video out feature - I hooked up a rca cable from the capture card's video-out to the video-in on my TV and then played the video using MPlayer and/or MPlayerClassic - it doesn't work. Obviously I am doing something wrong. What do I need to do to get this to work properly?
TIA
	Did you switch the TV to the Video Input you are using?
	Hi Bodyslide
 Yes - well actually it is going to my VCR then from the VCR to the TV - I tried all the different VCR output settings: - no picture . . .
 The TV is Old and does not have rca input
  Capture card for 360.. Capture in SD play on TV in HD?By fazeshot in forum Video Streaming DownloadingReplies: 4Last Post: 12th Nov 2009, 17:04
  Capture card or Video card w/ capture toolBy joelson in forum Newbie / General discussionsReplies: 1Last Post: 11th May 2009, 11:45
  Looking for new driver for video card- MEDION (7134) WDM Video Capture cardBy 2prfm.com in forum Capturing and VCRReplies: 3Last Post: 15th Sep 2008, 03:48
  Video capture card help! How do you capture from video card (desktop)?By AtiMike in forum Newbie / General discussionsReplies: 3Last Post: 24th Jun 2008, 17:50
  Using Capture/Recoding PCI card - GV-650 Video Capture CardBy Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 18:15
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
