Help!! I need a simple, Easy to use program that converts downloaded movies to DVD. I run windows Vista and have tried several freeware and trial programs with no results!!
For payware, try ConvertXToDVD. It handles most formats fairly well. And not that expensive for the convenience. But FAVC and DVDFlick also work well.
As many videos off the net are Xvid/Divx, you might also consider just using a Divx settop player and avoid re-encoding all together.
Searching for software used in conversion
By Mildragon in forum Video ConversionReplies: 0Last Post: 8th Oct 2011, 16:51 -
Advice on Conversion software
By tcory in forum Video ConversionReplies: 7Last Post: 22nd Sep 2011, 23:19 -
free conversion software????
By dj10fld in forum Video ConversionReplies: 1Last Post: 12th Sep 2008, 12:18 -
Ultimate conversion software? Like GK?
By Immortal25 in forum DVD RippingReplies: 1Last Post: 23rd Sep 2007, 10:17 -
Proffesional Conversion Software
By bigal260 in forum Video ConversionReplies: 14Last Post: 4th Jun 2007, 22:12
