Before I will try to combine the subtitles with the video again, is there any possibility of this switch in VDub to fix the problem?
Results 31 to 34 of 34
Not sure if you have to re-encode using that option in vdub, or if a direct stream copy would work
When you change the fps (e.g. from 50.00 to 50.02) you are essentially shrinking the video duration. Once again, you use the exact discrepancy given in mediainfo between the 2 files. This was given as option #2 already
You can use avi frame rate adjust to do this, here is a guide
http://www.gromkov.com/faq/faq2004-0064.html
If you want a perfect sync with the proper frame rate (e.g. perfect 50.00, assuming that was the correct fps) option #1 should work, but you have to re-encode (do the whole process from the beginning) -
Here is the result:
The original avi
And the resultCode:General Complete name : C:\Documents and Settings\Andrew\Desktop\Section1.avi Format : AVI Format/Info : Audio Video Interleave File size : 1.08 GiB Duration : 47mn 15s Overall bit rate : 3275 Kbps Writing library : VirtualDub build 29896/release Video Format : MPEG-4 Visual Format profile : Simple@L1 Format settings, BVOP : No Format settings, QPel : Noa Format settings, GMC : No warppoints Format settings, Matrix : Default Codec ID : XVID Codec ID/Hint : XviD Duration : 47mn 15s Bit rate : 3064 Kbps Width : 720 pixels Height : 576 pixels Display aspect ratio : 5/4 Frame rate : 50.000 fps Standard : PAL Resolution : 8 bits Colorimetry : 4:2:0 Scan type : Progressive Bits/(Pixel*Frame) : 0.148 Stream size : 1.01 GiB (94%) Writing library : Lavc51.49.0 Audio Format : MPEG Audio Format version : Version 1 Format profile : Layer 3 Codec ID : 55 Codec ID/Hint : MP3 Duration : 47mn 15s Bit rate mode : Constant Bit rate : 192 Kbps Channel(s) : 2 channels Sampling rate : 44.1 KHz Resolution : 16 bits Stream size : 64.9 MiB (6%) Alignment : Split accross interleaves Interleave, duration : 20 ms (1.00 video frame) Interleave, preload duration : 500 ms
Code:General Complete name : C:\Documents and Settings\Andrew\Desktop\New Folder\Section1.avi Format : AVI Format/Info : Audio Video Interleave File size : 1.31 GiB Duration : 47mn 15s Overall bit rate : 3980 Kbps Writing library : VirtualDub build 29896/release Video Format : MPEG-4 Visual Format profile : Simple@L1 Format settings, BVOP : No Format settings, QPel : No Format settings, GMC : No warppoints Format settings, Matrix : Default Codec ID : XVID Codec ID/Hint : XviD Duration : 47mn 15s Bit rate : 2550 Kbps Width : 720 pixels Height : 576 pixels Display aspect ratio : 5/4 Frame rate : 50.000 fps Standard : PAL Resolution : 8 bits Colorimetry : 4:2:0 Scan type : Progressive Bits/(Pixel*Frame) : 0.123 Stream size : 862 MiB (64%) Writing library : Lavc51.49.0 Audio Format : PCM Format settings, Endianness : Little Format settings, Sign : Unsigned Codec ID : 1 Codec ID/Hint : Microsoft Duration : 47mn 15s Bit rate mode : Constant Bit rate : 1411.2 Kbps Channel(s) : 2 channels Sampling rate : 44.1 KHz Resolution : 16 bits Stream size : 477 MiB (35%) Interleave, duration : 20 ms (1.00 video frame) Interleave, preload duration : 500 ms
Sorry for double posting, but I have tried to extract the audio from the original video and to mux it into the result video and it worked! But before this I`ve tried to re-encode the audio with the same codec and it still was desync, who knows what`s wrong now with Virtual Dub as before it did not do those stupid things. I hope that this works with the other section. Thank-you poisondeathray so far for your help and suggestions, I really appreciate it.
Help me about hardsub please!
By slimfit in forum Newbie / General discussionsReplies: 2Last Post: 20th Jun 2011, 21:53 -
extracting hardsub
By Benjy in forum SubtitleReplies: 0Last Post: 17th Jan 2011, 10:40 -
Hardsub and keep the style
By teclas in forum SubtitleReplies: 5Last Post: 20th Dec 2010, 23:35 -
Hardsub without reencoding?
By oguime in forum SubtitleReplies: 3Last Post: 9th Aug 2010, 07:42 -
Making Softsub into Hardsub
By iKhoa in forum SubtitleReplies: 0Last Post: 2nd Jul 2010, 14:58
