TMPGEnc has this feature where you can specify the bit rate manually for sections of the video (Manual VBR). I can't find anything called that for HCEnc. The best I can tell is that "Zones" is something like it. I'm guessing that 1 = max bitrate and 0.5 would equal half max bitrate. Is that right? If so, what effect will the average bitrate setting have if I use zones?
none.
avg bitrate remains,
but bitrate distribution per section is manually (relatively) overriden"I'll give you five dollars if you let me throw a rock at you" -
You can enter a value of 0.2 to 5 for each zone, but the manual doesn't say how the value really affects the bitrate. It only says that you can raise and lower it: 1 makes it normal and 0.5 (example given in program) makes it "lower". Does 5 make it 5 times the normal bitrate? What is the "normal" bitrate?Originally Posted by 45tripp
Is there a special HCEnc forum where the author hangs out? -
From TFM:
You specify the (average) bitrate separately. So it looks like "ZONE" multiplies that rate in the specified range of frames.*ZONE
parameter nr.of zones type integer Status not required
Example:
*ZONE 3
1200 1.3
1500 1.
2700 0.5
This command raises or lowers the bitrate for parts of the video.
The example will raise the bitrate starting at frame 1200, reset to normal at frame 1500 and lowers
the bitrate starting at frame 2700.
The number of zones is limited to 6400.
You can do this in the GUI, see "Preview/Zones" tab. -
How zones is implemented in HCenc (2 pass encode):TMPGEnc has this feature where you can specify the bit rate manually for sections of the video (Manual VBR). I can't find anything called that for HCEnc. The best I can tell is that "Zones" is something like it. I'm guessing that 1 = max bitrate and 0.5 would equal half max bitrate. Is that right?
The first pass is always done with a fixed Quantizer, resulting in a compression curve for the whole movie which will be scaled and tweaked, giving the frame sizes for the second pass.
The zones command will linear scale the compression curve but the final change of the curve using zones is limited because of other constraints like min/max bitrate and VBV.HCenc at: http://hank315.nl -
So, if the first pass curve has already decided to give frames in a zone the max bitrate, then nothing really happens if you try to raise it?Originally Posted by hank315
I think I figured out why the 0.2 lower limit. "times 0.2" is like "divide by 5".
Since it's still only v0.23, will you be implementing true CBR or MVBR in the future, or does the way HCEnc works prevent those things entirely? -
True, nothing happens.So, if the first pass curve has already decided to give frames in a zone the max bitrate, then nothing really happens if you try to raise it?
Maybe CBR will be implemented some day...Since it's still only v0.23, will you be implementing true CBR or MVBR in the future, or does the way HCEnc works prevent those things entirely?
I'm just not that keen to implement an encoding method which is IMHO not very good.HCenc at: http://hank315.nl
HCenc and PanScan
By Comp360 in forum Video ConversionReplies: 2Last Post: 14th Mar 2011, 18:35 -
Problem with HCenc 0.24.
By HolyFries in forum Video ConversionReplies: 2Last Post: 17th Jun 2010, 19:03 -
By HolyFries in forum Newbie / General discussionsReplies: 0Last Post: 17th Jun 2010, 14:18 -
HCenc Question
By Maikeru-sama in forum Video ConversionReplies: 6Last Post: 18th Aug 2008, 13:01 -
HCEnc
By Belfour in forum DVD RippingReplies: 1Last Post: 28th Jun 2007, 10:57
