Well, at least for that one feature that lets you keep programs from showing up on the most-recently used programs list on the Start menu. I'm the one who maintains the Vista system, but it's a family setup, and I'd rather keep certain maintenance/tweaking programs (among others) out of their sight. Sometimes, I do forget to remove them from the list after using the programs.
TweakUI itself supposedly only worked with the RTM builds of Vista. Anyone else know for sure?
You could try TweakVI : http://www.totalidea.com/content/tweakvi/tweakvi-index.php
Read my blog here.
you could also try...
right click on taskbar...properties...Start Menu tab...Privacy...uncheck "Store and display a list of recently opened files" and uncheck "Store and display a list of recently opened programs"..just a thought
mastersmurfie -
Yeah, I know I could just disable the Recent Programs list, but we're all actually using it. (Even me, and I normally disable it on my private systems...)
guns1inger: I took a look at TweakVI, and all I've found so far is an option to hide items from the regular Start menu. Well, if TweakVI didn't try to cram too much into all the windows...If cameras add ten pounds, why would people want to eat them?
A decent substitute for DVD Maestro
By Drakul in forum Authoring (DVD)Replies: 12Last Post: 8th Mar 2012, 21:11 -
ANYDVD HD Substitute
By pandemonium in forum Blu-ray RippingReplies: 11Last Post: 8th Jan 2012, 21:16 -
Substitute to Streamtransport !
By augustya in forum Software PlayingReplies: 9Last Post: 15th Jul 2011, 12:30 -
iuvcr substitute
By marcolisi in forum Capturing and VCRReplies: 1Last Post: 4th Aug 2010, 13:50 -
staxrip for mac substitute?
By malakov08 in forum MacReplies: 7Last Post: 9th Apr 2009, 00:57
