I have some MKV files which i would like to stream to my PS3.
the problem is when i play the files on my PC i get sound but no picture.
I have tried all the reccomened media players with no joy.
Now i understand my PC may not be upto the job of playing these files. (so a new PC may have to be bought)
This is stange as some of the MKV files are over a year old and used to work on my PC with VLC player.
What i would like to do is play these files through my PS3 but i have to convert them, however if i cannot view the video i assume i cannot convert them to MP4 files as i dont have the correct codecs and my PC cannot handle the files would this be correct?
I've been able to play some WMV files that were VC-1 on my PS3
VC-1 = Microsoft
At least I think so ...
If I'm correct then try installing WMV from the Microsoft website also make sure you install the newest version of Windows Media Player aka WMP as I think that will install all the needed codecs (knock on wood).
You will probably have to extract the files from the MKV and remux using the Microsoft WMV tools. The audio may need to be re-done to work correctly on the PS3. I used Goldwave to convert to 9.2 WMA as the files I had with VC-1 were using some 5.1 WMA format that works on the XboX 360 but not the PS3. The end result was normal 2 channel stereo audio though ... but I've never been a fan of surround sound anyway so it didn't bother me.
Maybe posting more information about the MKV or the separate files (once you demux) would be helpful.
What version of the PS3 system firmware do you have?
I believe support for playing VC-1 (at least in WMVs) was added somewhere around 2.10-2.17. There probably isn't a way to get the PS3 to play it in any other container (c'mon, Sony, add MKV playback support. Please? :P )If cameras add ten pounds, why would people want to eat them? -
i have the lastest firmware onthe PS3.
i realize that i may have to convert to an MPEG 4 format.
but as i stated if my pc cannot play the video i dont think it will covert either.
i should also state that my pc is quite old, 1.6 amd with 1gig ram
MKV to whatever files that the PS3 plays WITH subtitles WITHOUT Transcoding
By Abba91 in forum Video ConversionReplies: 36Last Post: 29th Apr 2012, 12:44 -
Why video and audio out of sync while playing .mp4 and .mkv files?
By Bonie81 in forum Software PlayingReplies: 0Last Post: 6th Apr 2010, 18:03 -
advice for editing m2ts files from ps3
By acnescar in forum Newbie / General discussionsReplies: 6Last Post: 10th Jan 2009, 17:54 -
Suggested encode of MKV files for PS3 playback
By fwtong in forum ffmpegX general discussionReplies: 2Last Post: 24th Jul 2008, 21:46 -
Can a PS3 play mkv x264 files?
By EatMoreChickens in forum DVD & Blu-ray PlayersReplies: 2Last Post: 17th Mar 2008, 08:28
