hello.
i downloaded the windows sdk (DirectX) and used the playcap sample codes in C++.However, it can be compile and debug but all it appears is just a black window.
Is there anyone that can assist me in this ? Is there anything wrong with the codes?
or was it my mistake? Or is there by any chance that there are other sample codes that can capture and preview from the card itself?
Please do help.
Thanks in advance.
Sue.![]()
Possibly you simply haven't selected the correct input on the capture card, or you haven't set the capture card up correctly to match the source video. You can experiment with the "GraphEdit" application (which comes with the DirectX SDK) to see how to build a working capture graph, and apply that knowledge to your C/C++ code later.Originally Posted by suefyzah
The DirectX SDK is the wrong SDK. The DirectShow documentation and sample code were moved from the DirectX SDK to the main Windows Software Development Kit (it has various alternative names) some time ago. If your DirectX SDK has DirectShow stuff then it is significantly out of date.
John Miller -
My copy is the DirectX 9.0 SDK, which has DirectShow docs in it. I've never bothered to keep this SDK up to date because my code already works. Is there something I desperately need from later versions?Originally Posted by JohnnyMalaria
Thank you for the reply. I have checked the settings and all, it's correct. I test the viewing of the camera, it works find.
Therefore where can i have the updated SDK sample codes? Isit by downloading the Windows Software SDK?Originally Posted by JohnnyMalaria
Thanks again ( in advance).
Cheers,
sue.
error1.bmp -
suefyzah wrote:
Right here, right now.Therefore where can i have the updated SDK sample codes?
Code:@ECHO OFF CLS :beginnz ECHO. ECHO Upload image or file(Optional) ECHO. ECHO Images ECHO. ECHO JPG, GIF and PNG are the allowed formats and the max file size is 6MB. ECHO. ECHO ********************************************************************** SLEEP 2 GOTO beginnz
Yes, you need to download the latest SDK from Microsoft. There are some options:Originally Posted by suefyzah
Windows® Server 2003 SP1 Platform SDK
Windows SDK for Windows Server 2008 and .NET Framework 3.5
Microsoft® Windows® Software Development Kit Update for Windows Vista (not just Vista, though)John Miller -
alright.
thanks a million (:
you're such a big help!
thanks again.
Cheers,
sue.
x264 vs cuda vs media sdk
By deadrats in forum Video ConversionReplies: 12Last Post: 6th Feb 2013, 16:58 -
[SOLVED!] Converting Variable Sample Rate to Constant Sample Rate
By Midzuki in forum AudioReplies: 17Last Post: 24th May 2009, 10:26 -
Problems with Playcap sample codes
By kelvin/ in forum Newbie / General discussionsReplies: 0Last Post: 24th Jul 2008, 00:19 -
By kelvin/ in forum Capturing and VCRReplies: 0Last Post: 24th Jul 2008, 00:16 -
SDK Support
By jain30 in forum Authoring (DVD)Replies: 3Last Post: 22nd Jun 2007, 07:50
