I have been taking movies in an avi format, making the MPEGs and adding menus and scene selections using DVD Lab Pro. After I have made my menus the .dal file compiled successfully and had no issues. I am using CopyToDVD as an add on plugin to burn the authored DVD. When I started to burned my DVD it went through the catching files and then gave this error. I am using DVD+R discs with a Toshiba laptop. I can't figure out what the hardware error means. Here is a picture of the screen i see.
	Bad idea. Try ImgBurn. If it gives you a similar error message, then it's probable thatI am using CopyToDVD as an add on plugin to burn the authored DVD.
 your DVD-drive really has a problem.
 Other things:
 Upload image or file(Optional)
 Images
 JPG, GIF and PNG are the allowed formats and the max file size is 6MB.
	So then how do i burn my DVDs with this burner since I thought you can only save your movies as .dal file? Id there a way to save it as a DVD or a .VOB or .VOB?
  Menus in DLPBy ckurowsk in forum Authoring (DVD)Replies: 1Last Post: 14th Oct 2008, 23:30
  Motion Menus in DLPBy ckurowsk in forum Authoring (DVD)Replies: 8Last Post: 8th Sep 2008, 09:23
  CopytoDVD IssueBy Cybrex in forum DVD RippingReplies: 1Last Post: 30th Jun 2008, 19:14
  out of memory ( DLP )By pcb in forum Newbie / General discussionsReplies: 19Last Post: 12th May 2008, 14:33
  Error I get after I finish copying a dvd with copytodvdBy litzg5 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 8th Feb 2008, 15:17
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
