Hi,
Could you help me resolve this issue.
I have not used the device for some time(it did work) and now when I run WinDVD Creator or Nero the device is not recognised.
I have uninstalled and re-installed, tried newer driver but no result. Un-insatlled all USD device as well.
When I open nero Vision I get the following error:
"No supported capture device was recognized"
The same happens in WINDVD Creator(comes with the device).
However, the device is recognised when I plug in ( a sequence of two USB recognition tones, a short pause, then one more tone).
The device is present in the device manager.
Please see attached results of PXInfo.exe. A PC configuration setup up program from plextor (SYSInfo.txt).
I could not read this but the data may help the more informed.
I also check with a USB monitor and there are no error reports.
I have XP SP3 installed on DELL Inspiron 6000.
Kind Regards In Advance,
Eric Walker
Sydney Australia.
SYSInfo.txt
PXInfo V1.26
Copyright(C) 1999-2007 Plextor SA/NV
Thursday, 24 July 2008
Software Information
Operating system : Windows XP V5.01.2600 Service Pack 3
ASPI (wnaspi32.dll) : n/a
Roxio ASPI (cdral.dll) : Sonic Solutions CDRAL DLL, V9.0.5.10 (not used by PXInfo)
Ahead ASPI (wnaspi32.dll) : Win32 Nero Aspi Library V2.0.1.74 (not used by PXInfo)
InterVideo WinDVD Creator 2 Version: 2.0.14.588
Hardware Information
Note: Buffer Underrun Proof is only read out
CPU 1:
CPU Name: Intel(R) Pentium(R) M processor 1.86GHz
CPU Speed: 1861 MHz
Installed RAM: 1023MB
Memory Available: 434228KB
Percent of used RAM: 58%
IDE Interface: 0 ID: - Maximum # Targets : -
Description :
Type :
Port Driver : atapi.sys
Provider :
Description : IDE/ATAPI Port Driver (Microsoft Corporation)
Version : 5.1.2600.5512 (xpsp.080413-2108)
Date :
ID 0: HTS54808 0M9AT00 VMG4O
Volume Name:
Capacity: 71.72 GB
Free Space: 4.46 GB
__________________________________________________ ___________________
IDE Interface: 1 ID: - Maximum # Targets : -
Description :
Type :
Provider :
Date :
ID 0: _NEC DVD+-RW ND-6500A V203D
Other PnP devices
ID 0: ST332062 0A V0000
Volume Name: New Volume
Capacity: 102.77 GB
Free Space: 35.63 GB
ID 1: ST332062 0A V0000
Capacity: 97.65 GB
Free Space: 621.00 MB
ID 2: ST332062 0A V0000
Volume Name: Astea
Capacity: 97.65 GB
Free Space: 39.39 GB
Properties for Device 1:
Device ID : PCI\VEN_8086&DEV_2653&SUBSYS_01881028&REV_03
Device Description : Intel(R) 82801FBM Ultra ATA Storage Controllers - 2653
Driver : Not Available
Driver : {4D36E96A-E325-11CE-BFC1-08002BE10318}\0003
Service : pciide
Port Driver : C:\WINDOWS\system32\drivers\pciide.sys
Description : Generic PCI IDE Bus Driver (Microsoft Corporation)
Version : 5.1.2600.0 (XPClient.010817-1148)
Date :
Manufacturer : Intel
Friendly Name : Not Available
Location Information: PCI bus 0, device 31, function 2
Address : 2 0 31 0
UI (PCI Slot) Number: UI number not available, may be an on-board device!
Interfaces:
Child Devices:
PCIIDE\IDECHANNEL\4&16427A01&0&0
PCIIDE\IDECHANNEL\4&16427A01&0&1
Properties for Device 2:
Device ID : Intel-2653
Device Description : Primary IDE Channel
Driver : {4D36E96A-E325-11CE-BFC1-08002BE10318}\0004
Service : atapi
Port Driver : C:\WINDOWS\system32\drivers\atapi.sys
Date :
Manufacturer : (Standard IDE ATA/ATAPI controllers)
Location Information: Primary Channel
Address : 0 0 0 0
Interfaces:
Child Devices:
IDE\DISKHTS548080M9AT00_________________________MG 4OA5EA\5&3AD6C04B&0&0.0.0
Properties for Device 3:
Device Description : Secondary IDE Channel
Driver : {4D36E96A-E325-11CE-BFC1-08002BE10318}\0005
Service : atapi
Date :
Location Information: Secondary Channel
Address : 1 0 0 0
Interfaces:
Child Devices:
IDE\CDROM_NEC_DVD+-RW_ND-6500A___________________203D____\5&281D0FA6&0&0.0. 0
USB Device Information:
# Host Controller \\.\HCD0 found.
Intel(R) 82801FB/FBM USB Universal Host Controller - 2658
# Host Controller \\.\HCD1 found.
Intel(R) 82801FB/FBM USB Universal Host Controller - 2659
# Host Controller \\.\HCD2 found.
Intel(R) 82801FB/FBM USB Universal Host Controller - 265A
# Host Controller \\.\HCD3 found.
Intel(R) 82801FB/FBM USB Universal Host Controller - 265B
| |---> Port[1] = I/O device connected
# Host Controller \\.\HCD4 found.
Intel(R) 82801FB/FBM USB2 Enhanced Host Controller - 265C
| |---> Port[6] = I/O device connected
| | Cypress AT2+LP (VID:0x04B4 PID:0x6830)
| | USB Mass Storage Device
| |---> Port[8] = I/O device connected
| | Plextor ConvertX M402U (VID:0x093B PID:0xA102)
Extended Information:
PlexTools Professional Registry Information
General
Key not found!
CD Info
Key not found!
Digital Audio Extraction
Key not found!
CD Copy
Key not found!
AudioCD Maker
Key not found!
PlexTools Professional XL Registry Information
AutoStrategy Database
Results 1 to 1 of 1
Help needed with Video Capture - No VCR recognised on PC
By ULscot in forum Capturing and VCRReplies: 7Last Post: 14th Nov 2010, 12:14 -
I Have Nero 7 Ultra but Need Video Capture Device Recommendation
By Classic '57 in forum Newbie / General discussionsReplies: 2Last Post: 12th May 2009, 17:45 -
Plextor convertx px-m402u
By TyWelcome in forum Capturing and VCRReplies: 2Last Post: 18th Feb 2008, 21:43 -
Audio problems with Plextor M402U and Virtual Dub
By nrsgzz in forum Capturing and VCRReplies: 4Last Post: 6th Sep 2007, 17:27 -
Plextor M402U
By LeFreak in forum Capturing and VCRReplies: 5Last Post: 6th May 2007, 20:33
