Greetings all.
I have been streaming media for quite a few years with good success. I usually use VLC or WME9 to stream various media. However, I ran into a road block when I built a new computer. Generally I am good with VLC or WME9 but couldn't break this one.
I have a Haupaugge HVR 1600 tuner. It tunes cable/atsc/clear qam. However, I cannot get this card to work in anything other than windows media center... which is saying alot! First in VLC I cannot even get the card to open a regular CABLE channel (1-99) both in VLC and WME9. Also it has an Svideo input on it. I tried putting a video source to that and I couldnt get anything. When I select inputs in applications, i have (Tuner, Svideo 1 Composite 1 Svideo 2 Composite 2). However, no matter what I select I cant get anything!
Does any one know of a way to get this to work? If not, is there a card that is better tailored to what I want to do? Stream cable over network, tunes clear-qam (I'd love the ability to stream ATSC or clear-qam but wont hold my breath), and has a video input that can also be streamed.
Any thoughts or advice? Thanks alot!
System:
DFI LP X48 T2r
Intel q9450
ATI Radeon 4870
Creative Xfi
8 gigs of memory
Windows Vista Ultimate 64
Windows XP 64bit Edition (can boot either vista or XP)
In before "google is your friend" or "use search" cause I've done both.
Results 1 to 1 of 1
WinTV-HVR 1600 (video too dark)
By jolu in forum Capturing and VCRReplies: 13Last Post: 22nd Dec 2010, 20:25 -
Hauppauge HVR-1600 DTV to DVD
By trossin in forum Video ConversionReplies: 5Last Post: 20th Feb 2009, 14:24 -
HVR-1600 MCE on Athon - Fast enough?
By Cotys in forum Capturing and VCRReplies: 2Last Post: 26th Jan 2008, 12:29 -
HVR-1600 with illico Videotron
By micboule in forum Capturing and VCRReplies: 0Last Post: 16th Oct 2007, 19:42 -
Problems with HVR-1600 screenshots
By uscboy in forum DVB / IPTVReplies: 2Last Post: 20th Sep 2007, 09:37
