I am an XBMC user who has ripped some of my own collection to Xvid. Now I am finding I am dissatisfied with the quality. I have ISO copies of some disks as a test and they play well over my wireless connection to the Xbox XBMC.
I'd like to cut down the number of boxes under the tv and thought I'd like to start playing my rips through the Xbox 360.
What is the highest quality I can stream off a hard disk for the 360?
I stream .mp4/ h.264 to the Xbox,and AFAIK, the quality is great ,try it!.......
Others will post their preferences..To each his/her own....
" Who needs Google, my wife knows everything" -
MP4 container H.264 - I had read that was the best. What resolution to you encode PAL DVD. I was trying a couple of utilities last night and 720x388 or something came up.Originally Posted by t0nee1
I was expecting 720x580 (or 576) whatever the native resolution of DVD is. -
DVDs use non square pixels. When you compensate for this to get back to a 1:1 pixel aspect ratio, the numbers shake out a little differently.
If you were converting 16:9 (1.778:1) for Divx/Xvid you would normally end up with 720 x 400 or 640 x 368. if it is wider then the vertical will be smaller.
As you are streaming, you could try encoding 1024 x 576 (1.78:1 anamorphic source), and compare the picture quality to a 720 x 400 encoding on playback.Read my blog here.
Why won't the Xbox 360 playback .mp4 video
By smitbret in forum Media Center PC / MediaCentersReplies: 20Last Post: 9th Feb 2017, 09:52 -
Burned DVD playback on Xbox 360?
By cmcfalls in forum DVD RippingReplies: 3Last Post: 25th Mar 2011, 15:30 -
how do you record xbox 360 gameplay while using microsofts xbox 360 vga ?
By rushinplaya in forum Capturing and VCRReplies: 18Last Post: 3rd Apr 2010, 07:19 -
My last hope with .MP4 playback on xbox 360
By kanwar786 in forum Video ConversionReplies: 12Last Post: 18th Feb 2009, 13:05 -
Streaming HD movies off of external hard drive through xbox 360
By lindros in forum Video Streaming DownloadingReplies: 0Last Post: 26th May 2008, 00:58
