  1. I can't get AVS or VDR files to load into CCE v2.5 SP (DEMO). I have VFAPI, ReadAVS, AVIsynth, and Vdub Serving Drivers installed, but it still just crashes when I attempt to open a AVS or VDR.
    VFAPI AVIs load ok, but AVS and VDRs do not.
    Any suggestions ?
  2. Everything about CCE is great, except that it crashes too often. My suggestion is that in your CCE template, disable audio output. (You need to do audio separately with CCE). If it still crashes, try to add ResampleAudio(44100) in your AVS script, although I never used it. Haven't used VDR frameserver since I switched to Avisynth, which is faster and has all the filters I need.
  3. my AVS files don't contain the AUdio stream data.. and my template is also without Audio.. thanks thou.. .anyone have any suggestions ?
    has anyone actually got AVS file loading in CCE ?
  4. I have been using CCE 2.50 SP for a while and frameserving into it with Avisynth. Another suggestion is that you have to be very careful with syntax of your script. One blank line at the start of your script can cause CCE to crash. CCE is also very picky in what system it can run.
