I now own three devices (iPod Video/Samsung P2/Samsung Instinct) that I transfer video to in the MPG4 format. I use KeepVid to grab videos from YT, and then use Relay Converter to transfer to MPG4. In the past couple of days, while transferring to MPG4, my computer turns itself off close to the completion of conversion. I've tried uninstalling/reinstalling the programs I use, including Quicktime, to no avail. I've even disabled my screensaver thinking that might have something to do with it. I'm at my wits end (no smart remarks here!), so if anyone has any ideas what could be causing these shutdowns; I would be greatly appreciative. :)
Overheating is one possibility.
Check the Heat sink & fan assembly on the CPU and if the Chipset on the Mobo or Video card have fans check them too. If your computer details are accurate they are probablt in need of service. Also check the Power supply fan is working.
If when you turn on the cold computer you hear noises that go away as it warms up? That is a sign of one or more fans going bad.
format to use for fastest conversion from flv
By cduval04 in forum Video ConversionReplies: 2Last Post: 8th Oct 2011, 00:58 -
FLV Format
By Ttownboy23 in forum Newbie / General discussionsReplies: 1Last Post: 19th Apr 2009, 04:30 -
Converting from Flash .flv format to iPod Compatible .mp4 format in ffmpegX
By bananasontoast in forum ffmpegX general discussionReplies: 1Last Post: 3rd Jan 2009, 09:15 -
Problem with artifacts in flv conversion - i.e. converting to flv from avi
By brassplyer in forum Video Streaming DownloadingReplies: 9Last Post: 30th Apr 2008, 22:09 -
What is the best export format from Vegas for later FLV conversion?
By Gargalash in forum Video ConversionReplies: 1Last Post: 15th Apr 2008, 00:20
