Hey guys i can't see to get the video ini time with the audio
it seems that the video is skipping frames
i've tried changing the frame rate 12 a little bit slow 24 little bit slower and so on
This is the log:
Mac OSX universal build for ffmpegX
libavutil version: 49.0.0
libavcodec version: 51.9.0
libavformat version: 50.4.0
Seems that stream 1 comes from film source: 600.00 (600/1) -> 50.00 (50/1)
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/Users/admin/Desktop/Export_080727-180419.mov':
Duration: 00:03:11.7, start: 0.000000, bitrate: 46645 kb/s
Stream #0.0(eng): Audio: pcm_s16be, 44100 Hz, stereo, 1411 kb/s
Stream #0.1(eng), 50.00 fps(r): Video: qtrle, rgb24, 472x355
Output #0, 3gp, to '/Users/admin/Desktop/Export_080727-180419.mov.ff.3gp':
Stream #0.0, 18.00 fps(c): Video: h263, yuv420p, 176x144, q=2-24, 100 kb/s
Stream #0.1: Audio: aac, 44100 Hz, stereo, 12 kb/s
Stream mapping:
Stream #0.1 -> #0.0 [sync #0.0]
Stream #0.0 -> #0.1 [sync #0.1]
[h263 @ 0x54340c]warning, clipping 1 dct coefficients to -127..127
[h263 @ 0x54340c]warning, clipping 2 dct coefficients to -127..127
bench: utime=20.505s
video:1128kB audio:1379kB global headers:0kB muxing overhead 65.451220%
Encoding completed on Sun Jul 27 22:49:32 EST 2008
what does this mean?
Try activating Decode with QT. Possibly it may help in keeping sync. When it does, it is the most simple solution.Originally Posted by JayxDee
If your source file starts with audio without video, or starts with video without audio, then that may cause a loss of sync when the streams get encoded separately. For best results, the audio and video should both cover the full length of the movie. So, if you can, add silent audio to parts without audio before exporting. Using DV as an intermediate codec may help, as it forces full length audio and video.
You will see this warning a lot on H.263 encodings. Nothing to worry about. It is saying that some details in the video are outside the range that H.263 is capable of encoding to. Instead these details get the best possible approximation. Unrelated to sync issues.Originally Posted by JayxDee
Trouble ripping video and/or audio
By dexter30 in forum DVD RippingReplies: 8Last Post: 26th Feb 2010, 12:06 -
Trouble playing mp4 in VLC, audio is there, but no video
By brdhsby5 in forum Newbie / General discussionsReplies: 6Last Post: 9th Feb 2010, 14:06 -
video and audio time dont match?
By just in forum Newbie / General discussionsReplies: 4Last Post: 4th Nov 2008, 20:58 -
video and audio don't have the same time?
By just in forum Newbie / General discussionsReplies: 1Last Post: 30th Oct 2008, 07:17 -
Can you speed Video and Audio at the same time?
By Jerry1964 in forum EditingReplies: 6Last Post: 13th Jun 2008, 09:23
