Hello, i'm new to capturing video and i'm having difficulty transferring footage from my video camera to Adobe Premiere CS3.
My camera - Panasonic VDR-D300
I am trying to connect through USB and I get the Capture Device Offline message in the Capture window everytime I open it. I have installed the camera drivers, and I am able to access the files through a third party program (DVD-MovieAlbumSE) where I can export the files but only as .mpeg.
Any help? Thank you.
I didn't think CS3 supported any capture over USB. You should use the software that came with the camcorder and then try to import the resulting file. First check to see if the file format and codec are supported by CS3.
http://www.kiva.org/about -
That camcorder encodes everything to MPeg. That is what you have.Originally Posted by Haz567_a
Premiere CS3 should import the MPeg2 file but will recode every frame.Recommends: Kiva.org - Loans that change lives.
So firewire might be a better option?
Will there be any quality difference through importing straight into Premiere as opposed to using DVD-MovieAlbumSE to save the movie files first? -
I don't think that camcorder has a Firewire port. It's a DVDR cam. It encodes to MPeg2 on DVDR.Originally Posted by Haz567_a
http://reviews.cnet.com/digital-camcorders/panasonic-vdr-d300/4507-6500_7-31660692.html
No since nothing is being recoded.Originally Posted by Haz567_a
A quick look at Premiere CS3 camcorder support shows nothing for consumer DVDR camcorders. You will need to import the MPeg2 file.
http://www.adobe.com/products/premiere/search_result.html?manuSearchVar=1&modelSearchV...ras&format=PALRecommends: Kiva.org - Loans that change lives.
Steps to edit video in Adobe Premiere Pro CS3?
By LateFate in forum Newbie / General discussionsReplies: 0Last Post: 22nd Apr 2011, 09:21 -
Importing video/audio into Adobe Premiere Pro CS3
By JCW2001 in forum EditingReplies: 26Last Post: 15th Jan 2011, 21:39 -
Convert Video using Adobe Premiere Po CS3
By SB4 in forum Newbie / General discussionsReplies: 11Last Post: 5th Feb 2010, 01:43 -
Audio / Video interleave Adobe Premiere Pro CS3 problem
By mkrmec in forum EditingReplies: 5Last Post: 21st Aug 2008, 08:28 -
Adobe Premiere CS3 vs 2.0
By hanugro in forum Video ConversionReplies: 0Last Post: 31st Aug 2007, 08:26
