Not sure if this has been covered before. I did a search on this forum and can't find anything. I've looked for quite a while for an easy way to convert DVD9 to Half-D1 DVD5, but so far, nothing. Sometimes transcoding just doesn't cut it, and resizing IS the answer. The past several years, I have been doing it manually, converting the VOBs and editing the IFOs by hand. But there must be an easier way to do it by now, I would think, something similiar to CloneDVD, etc., that will reencode the VOBs to Half-D1 (or any other standard resolution) and edit the IFOs for you while keeping the menus, etc. I tried Virtualdub to see if that would do it, but it won't work properly on my Win2k3 system. I've also tried not editing the IFOs and processing the files through a couple apps that are "supposed" to "repair" buggy or poorly written menus, etc. to no avail. So, it leaves me spending quite a while rewriting IFOs with one hand with my calculator in the other, when I would think that there "should" be a program already available that will do it for me.
Thanks.
DvdRebuilder.
Options -> AVS Options -> Advanced (Expert) Options -> Resize to Half D1 > Apply to All
DVDRB re-encodes, it doesn't transcode. You may want to do a run at half D1 and one at full size and compare.Pull! Bang! Darn!
Convert MKV DVD9 to MKV DVD5
By CR88 in forum Video ConversionReplies: 1Last Post: 23rd Aug 2011, 08:55 -
DVD9 split to two DVD5's while retaining menus and video quality
By ashes2flames in forum DVD RippingReplies: 6Last Post: 28th Feb 2011, 09:10 -
DVD5 vs. DVD9
By Beaker14 in forum DVD RippingReplies: 1Last Post: 6th Nov 2009, 11:33 -
How do i convert an (ISO) dvd9 to a dvd5 and keep the menus???
By jcurrieirocz in forum Video ConversionReplies: 5Last Post: 26th May 2009, 09:15 -
how can i convert my dvd5 to dvd9
By scratchlikeme in forum Newbie / General discussionsReplies: 4Last Post: 29th Apr 2009, 21:54
