    Mar 2008
    India
    How to change the FPS of a subtitle file (SRT) easily? Any tool please?
    Dec 2004
    Triptonia
    any tool
    most will do.
    i use an old one called subtitle tool
    try subtitle workshop
    "I'll give you five dollars if you let me throw a rock at you"
  3. Or SubtitleCreator. File->Open Text Subtitle followed by Synchronize->Convert Frame Rate and finally File->Save SRT.
  4. Subtitle Edit has an option for that. Just tried it with version 2.9.1. Go to "options", "change frame rate". No install is required for this program.
