Hi..
after using smooth deinterlacer in vdub. it will make 25fps interlaced video into 50p video.
how can i make it back to 25p video??
				Results 1 to 10 of 10
	Video -> Frame Rate... -> Convert to fps [25]
 But does that filter really double the frame rate? You're talking about Gunnar Thalin's filter that shows up as "Deinterlace - Smooth v1.1"?
	Ah, I had a chance to read up on that filter. It doesn't really change the frame rate. You are supposed to use AviSynth to SeparateFields() before opening the video in VirtualDub. Changing the output frame rate in VirtualDub won't work right because the frame rate is halved before sending the frames to the filters.
 The best deinterlace filter I've found for VirtualDub is Donald Graft's Smart Deinterlace. Try it in "Edge directed interpolate" mode.
 But if you're using AviSynth to SeparateFields() why don't you use one of the good deinterlacers for AviSynth? LeakKernelDeint(), TDeint(), Yadif(), etc.
	He already suggested 3:
 TDeint()
 Yadif(Order=1,Mode=0)
 LeakKernelDeint(Order=1)
 The Order is for TFF. If BFF, then Order=0. They all have other parameters you can tweak if necessary. There are better deinterlacers but they're all too slow for my liking. These are the 3 best fast ones, in my opinion. Of the 3, I like Yadif the best.
	i have been working with (smart deinterlacer) for my footages. and it is good. but i dont like the look of flat kind of image it produce..
	hi manono and jagabo...
 i have found a good solution.. and i have posted it with my results..
 please check it at
 https://forum.videohelp.com/topic354397.html
 i gave credits to you guys too.
  Will 1080/50p 28Mbps from Camcorder playable on computer without re-encodeBy skydutch in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 32Last Post: 13th Nov 2011, 11:35
  HD Video File ( 1080 50P ) from Panasonics TM700By wisitch in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 22nd Aug 2011, 09:45
  AVCHD Spec Version 2.0 Updated 1080/60p , 50pBy poisondeathray in forum Latest Video NewsReplies: 6Last Post: 8th Jul 2011, 03:45
  Please help - Panasonic HDC-TM300 only 25pBy zZee in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 11th Mar 2011, 14:33
  50i to 25pBy kippard in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 11th Jun 2008, 07:34
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
