Hi,
I attached a picture file to show what http://www.grab.com/ is doing.
If picture is too small, I apologize, and hope its able to be made bigger?
There is no graphics, pictures, ... on the web site just a bunch of text? I have no clue what happened nor how to fix it? Please and thank you!
This site http://www.neopets.com/ is doing the samething also?
Both sites where working for me yesterday?
Is those site show text for everyone or just me? Please and thank you! If just me how is it able to be fixed? Please and thank you!
I tested my flash player and shockwave player because those sites both use and for other sites that use shockwave and flash player work well for me also?
Thank you so much!
Works for me:
Note, I have Firefox set up to override fonts and font sizes so the page probably looks weird.
You probably accidentally disabled java script or something like that. -
They work fine in IE7 also. I've had that happen a few times, even on this site. Usually closing IE and restarting it fixes it. I'm guessing it's some sort of problem with the program reading or displaying HTML properly.
If it only happens on those particular sites, try deleting the cookies for those sites and that may fix it.
If all else fails, you can reset IE or other browsers to the default settings, though you would lose your own custom settings.
Hi,
I tried to restart IE and still the samething. I have tried to load the sites in IE, netscape, and firfox and still the same thing.
Here is what I do not understand I am on a network and when I try the other 2 computer they all do the same thing?
To block sites
By Jomapil in forum ComputerReplies: 13Last Post: 24th Apr 2012, 20:12 -
Download Sites?
By wulf109 in forum ComputerReplies: 5Last Post: 8th Jul 2009, 19:19 -
Undesired sites
By Jomapil in forum ComputerReplies: 12Last Post: 15th Feb 2009, 15:09 -
Best MP3 pay sites out there?
By Super Warrior in forum Off topicReplies: 9Last Post: 16th Apr 2008, 18:37 -
Cannot Access certain sites
By dudesmn in forum ComputerReplies: 68Last Post: 8th May 2007, 17:46
