Hi - I have a lot of .mpg files of varying volume that I string together on DVD. Is there any easy/batch way to normalize the audio for these on a permanent basis.
As a followup, if there is such way to do this, would other batches be normalized similar? Let's say I normalize a batch of mpgs today and then tomorrow, I normalize another batch. Would those two batches be normalized as to where I could mix and match the files and they will be at similar volume levels, or do the files normalize to each other (thus, the first batch would be at similar volume levels to each other but not to the second batch?)
I'm not afraid to demux if I have to.
Thanks for any help!
Really tough to do with Mpeg files because of the sync problems that happen with demuxing and remuxing.
so, would i have to convert them to something and then convert them back?
Well, you could do that but you'd lose a good deal of quality. It would be so much easier if they were AVIs.
https://forum.videohelp.com/topic314909.html
With MPEG2s, you'd have to:
Demux the Audio and Video with DGindex
Convert the Audio to stereo WAV
Normalize the WAV
Convert the WAV to Mp2 or AC3
ReMux the new audio track to the correspoding video track
Big PITA. -
Hello Soop, I had the same problem many, Many, Many years ago...!
Since you are making DVD - maybe do what I did...!
I bought a copy of DVD Author Pro by Pegasys software (Used to be called Tsunami Software).
This software lets you normalize the audio among all of the tracks.
I Level the audio manually - It only takes a few minutes..!
Tug_Hill2Reach for the Starz
what is the best way to normalize an ac3 audio?
By sgbd in forum Video ConversionReplies: 1Last Post: 24th Sep 2010, 14:46 -
how do I normalize too silent audio
By Aivc in forum AudioReplies: 1Last Post: 15th Apr 2010, 13:30 -
Is there a way to batch normalize audio of MPG2
By mehnihma in forum AudioReplies: 3Last Post: 6th Mar 2010, 00:15 -
How to 'normalize' the audio on a batch of videos?
By Captain Satellite in forum Video ConversionReplies: 5Last Post: 17th Jun 2008, 13:51 -
Normalize AC3 Audio
By dridge in forum AudioReplies: 3Last Post: 26th Nov 2007, 12:12
