I`ve been using BoilSoft Video Joiner and I`m still having this problem. I am trying to join 10 avi files of about 100MB each, XVid encoded 50FPS and the audio is Lame MP3 192kbps CBR. I`ve also tried Easy Video Joiner but it has a problem, starting from the 2nd joined video, I cannot hear any sound (this happens to any kind of avi file I try to join. I would like to know if there is any solution to my problem.
Results 1 to 29 of 29
Read my blog here.
I can`t believe it, the problem is back now, just that it`s MUCH more worse!
I did the same thing, appended all the video files that I needed. I check the final video file and find out that after the half of the video the sound gets choppy! I`ve tried to open it, and append the rest with VirtualDub but it says:
"Cannot append segment '*path to file*': The audio streams have incompatible data formats. (Mismatch detected in opaque codec data at byte 20 of the format data)
I did not apply a different method than the one that I used before (for DVD ripping, splitting, etc.) and used the same quality rates! -
Erm, if you would look by four posts above you would see that you already suggested to me that, so that results naturally that I used it this time before trying VirtualDub...
Originally Posted by andy_blah
So what happened when you tried AVI Demux ?
It might also be worth posting either mediainfo outputs or g-spot screen shots of the file sin question so we can see what you are working with.Read my blog here.
General
Complete name : C:\Documents and Settings\Andrew\Desktop\Section1.avi
Format : AVI
File size : 1.05 GiB
Duration : 44mn 33s
Overall bit rate : 3370 Kbps
Video
Format : MPEG-4 Visual
Format profile : Simple@L3
Format settings, BVOP : No
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 44mn 33s
Bit rate : 3192 Kbps
Width : 720 pixels
Height : 576 pixels
Display aspect ratio : 5/4
Frame rate : 50.000 fps
Standard : PAL
Resolution : 8 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.154
Stream size : 1018 MiB (95%)
Writing library : XviD 1.2.0.dev47 (UTC 2006-11-01)
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Codec ID : 55
Codec ID/Hint : MP3
Duration : 44mn 33s
Bit rate mode : Constant
Bit rate : 128 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Resolution : 16 bits
Stream size : 51.1 MiB (5%)
Alignment : Aligned on interleaves
Interleave, duration : 26 ms (1.31 video frame) -
in any case,
i'd take each section,
direct stream copy video, audio to full uncompress,
then
append,
direct stream copy video, compress audio
tripp"I'll give you five dollars if you let me throw a rock at you" -
You mean as in export the audio of the source files to wav, join them, and after that to add them to Section1.avi?
no i mean create section1new.avi with uncompressed audio,
an so on...
then append sectionnew.avi files, and when exporting recompress audio."I'll give you five dollars if you let me throw a rock at you" -
I must tell you that this section1.avi was done in AviDemux, not in VirtualDub. If you will read above you would see why. And section1.avi has that audio problem in it already, recompressing the audio won`t do any good.
you've not written it.
Originally Posted by andy_blahOriginally Posted by andy_blah
what you did,
what failed,
how it failed.
if you;re running a mishmash approach,
no one will follow.
how'd you expect to correctly append?
and again if step 0 is problematic,
trying to go to uncompressed, is a sound idea,
unless the audio is damaged and beyond salvage,
in which case, quit.
Ok then, I will have no choice, just to repeat myself *sigh*
What I used last time, and it worked (on joining): AviDemux
What I used this time, and failed: AviDemux - problem: audio is choppy after the second half of the video
What I tried to use further: VirtualDub - failed - message after appending different avi segments: "Cannot append segment '*path to file*': The audio streams have incompatible data formats. (Mismatch detected in opaque codec data at byte 20 of the format data) <- and this was the reason of not using VirtualDub for appending avi segments
I cannot understand what you mean by all the "uncompressed". Maybe if you would tell me in which program I should do that and precisely how to do it.
Might be a stupid question, but what do you mean by "Step 0"? -
before even attempting to append, hence you'd need to see to that before attempting appendage.
so i dubbed it step 0.
set 'video' ->'direct stream copy'
set 'audio' ->'full processing mode'
'save as' section1new.avi
repeat for section2, section3,....
open section1new.avi,
append section2new, section3new,....
set 'audio' ->'full processing mode' & set 'compression' to lame mp3.
save avi.
try appending in avidemux as well.
you could also try to disable audio and mux video only,
demux each audio to full uncompressed .wav, and use an audio editor to work at it,
compress and mux.
they might not be appendable, in which case you have to join in avisynth reencode everything.
the audio might be buggered,
in which case good luck.
and when gunslinger said post info,
he meant a grab on at least 2 of the streams you plan to append,
to compare their properties.
I`ve done that uncompressed audio method you suggested me to, but it still says: "Error Initializing audio stream decompression:
No installed audio codec could be found to decompress the compressed source audio." But I do have that specific codec (which is Lame MP3)
Here is some information about two of the videos that I`ve been trying to join:
Code:General Complete name : E:\New Folder\01.avi Format : AVI Format/Info : Audio Video Interleave File size : 76.4 MiB Duration : 3mn 38s Overall bit rate : 2937 Kbps Video Format : MPEG-4 Visual Format profile : Simple@L3 Format settings, BVOP : No Format settings, QPel : No Format settings, GMC : No warppoints Format settings, Matrix : Default Codec ID : XVID Codec ID/Hint : XviD Duration : 3mn 38s Bit rate : 2781 Kbps Width : 720 pixels Height : 576 pixels Display aspect ratio : 5/4 Frame rate : 50.000 fps Standard : PAL Resolution : 8 bits Colorimetry : 4:2:0 Scan type : Progressive Bits/(Pixel*Frame) : 0.134 Stream size : 72.3 MiB (95%) Writing library : XviD 1.2.0.dev47 (UTC 2006-11-01) Audio Format : MPEG Audio Format version : Version 1 Format profile : Layer 3 Codec ID : 55 Codec ID/Hint : MP3 Duration : 3mn 38s Bit rate mode : Constant Bit rate : 128 Kbps Channel(s) : 2 channels Sampling rate : 44.1 KHz Resolution : 16 bits Video delay : 11ms Stream size : 3.33 MiB (4%) Alignment : Split accross interleaves Interleave, duration : 20 ms (1.00 video frame) Writing library : LAME3.98ŞŞŞŞŞŞŞŞŞŞŞŞ
Code:General Complete name : E:\New Folder\02.avi Format : AVI Format/Info : Audio Video Interleave File size : 52.3 MiB Duration : 2mn 16s Overall bit rate : 3201 Kbps Video Format : MPEG-4 Visual Format profile : Simple@L3 Format settings, BVOP : No Format settings, QPel : No Format settings, GMC : No warppoints Format settings, Matrix : Default Codec ID : XVID Codec ID/Hint : XviD Duration : 2mn 16s Bit rate : 3044 Kbps Width : 720 pixels Height : 576 pixels Display aspect ratio : 5/4 Frame rate : 50.000 fps Standard : PAL Resolution : 8 bits Colorimetry : 4:2:0 Scan type : Progressive Bits/(Pixel*Frame) : 0.147 Stream size : 49.7 MiB (95%) Writing library : XviD 1.2.0.dev47 (UTC 2006-11-01) Audio Format : MPEG Audio Format version : Version 1 Format profile : Layer 3 Codec ID : 55 Codec ID/Hint : MP3 Duration : 2mn 16s Bit rate mode : Constant Bit rate : 128 Kbps Channel(s) : 2 channels Sampling rate : 44.1 KHz Resolution : 16 bits Video delay : 25ms Stream size : 2.09 MiB (4%) Alignment : Split accross interleaves Interleave, duration : 20 ms (1.00 video frame) Writing library : LAME3.98ŞŞŞŞŞŞŞŞŞŞŞŞ
Actually, I meant only these:
Code:Audio Format : MPEG Audio Format version : Version 1 Format profile : Layer 3 Codec ID : 55 Codec ID/Hint : MP3 Duration : 3mn 38s Bit rate mode : Constant Bit rate : 128 Kbps Channel(s) : 2 channels Sampling rate : 44.1 KHz Resolution : 16 bits Video delay : 11ms Stream size : 3.33 MiB (4%)
Code:Audio Format : MPEG Audio Format version : Version 1 Format profile : Layer 3 Codec ID : 55 Codec ID/Hint : MP3 Duration : 2mn 16s Bit rate mode : Constant Bit rate : 128 Kbps Channel(s) : 2 channels Sampling rate : 44.1 KHz Resolution : 16 bits Video delay : 25ms Stream size : 2.09 MiB (4%)
posted info on.
that's a total of 5mb only,
demux the audio from each file.
and poisondeathray means to double check,
can you uncompress any mp3 file in vdub?
is it failing only on these files?
and my methodology still stands.
change the tools until something works,
or until nothing works.
but the method is the same.
ie start trying the process in avidemux
Here it is: http://rapidshare.com/files/136339040/mp3s.zip.html (I prefer uploading to Rapidshare, sorry)
I was going over the splitted videos and I observed that some were at 128, some at 192, can this be one of the causes?
What process should I start in Avidemux? -
they join fine too.
lame acm, for vdub
as poisondeathray mentioned, ( http://www.rarewares.org/mp3-lame-dshow-acm.php )
mp3->uncompressed audio,
then join, then recompress audio.
(plus fallback solutions)
joining mp4 files but audio out of sync
By Liselotte in forum Newbie / General discussionsReplies: 2Last Post: 1st Aug 2011, 21:18 -
audio sync problem joining two avi files
By kthan in forum EditingReplies: 11Last Post: 2nd Apr 2011, 12:52 -
Joining Multiple AVI files...
By phorkster in forum EditingReplies: 4Last Post: 13th May 2010, 15:43 -
how do I join multiple avi files with multiple audio tracks?
By helloguys in forum EditingReplies: 1Last Post: 26th Dec 2007, 02:28 -
I'm new to Joining multiple avi files into one big file....
By Lahori82 in forum EditingReplies: 4Last Post: 29th Aug 2007, 13:05
