I demuxed the .TS with tsMuxeR and got a .dts audio file along with the video. Encoding the .mpv into h.264 worked fine with MeGUI, but muxing it together with the .dts sound into a .mkv using mkvmerge just kept giving me warnings "Warning: dts_packetizer: skipping 3 bytes (no valid DTS header found). This might make audio/video go out of sync, but this stream is damaged." and then ultimately stopped.
I then tried to use gdsmux (aka: DS Mux, Haali Media Splitter) instead, but it wouldn't accept the .dts audio, giving me this "Can't open file: No combination of intermediate filters could be found to make the connection."
Lastly I tried MeGUI's mkv muxer but it would just go to 28% where it stopped and nothing more happened.
I really need someone to help me to get this to work (to create a .mkv with both the h264 video and the audio in it), although it does feel as if something is wrong with my .dts audio file, maybe I should re-extract the .ts audio in some other way to make it work?
ADVC Mini doesn't work properly
By keyboardboy in forum MacReplies: 32Last Post: 1st Dec 2016, 22:23 -
Just can't get stabilization work properly.
By Jim Halpert in forum Newbie / General discussionsReplies: 9Last Post: 24th Nov 2009, 11:58 -
Canīt properly separate audio from video
By dexter30 in forum AudioReplies: 2Last Post: 29th Oct 2009, 20:44 -
Can't get DGIndex to work properly
By iTayb in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 38Last Post: 22nd Aug 2009, 21:38 -
Can't get .mkv subtitles to display/work properly
By ChronoSquare in forum SubtitleReplies: 3Last Post: 26th Dec 2007, 15:36
