I have Vegas Pro 8.0b and Architect 5.x..
I cant figure out how to generate from (any) video source, a file that architect can take that wont need recompression?
Architect will not need to recompress m2ts files from my canon hf10, but if i take say my mpeg mov files from my panasonic (1280x720 at 30p original) which i have converted to mpeg2, it always says it needs to recompress.
I convert those movs to mainconcept mpeg2 m2t files, set at 1920x1080@60i.. this res matches the bluray template i'm using in Architect..
Is there another setting or file extension i must use, so i can basically get the movs rendered to another format and then not need to re-render in DVD-A?
Thanks in advance
Sorry that I'm unable to help with your problem, however I just had to ask, have you successfully authored any Blu-ray discs with menus from your HF10 footage?
I'm a long time Vegas 7/DV camera owner looking to upgrade to 8 Pro/DVD Architect Blu-ray update and possibly a Canon HF11 camcorder so I'm ultra keen to hear your thoughts on the experience! -
I have authored some bluray titles..
I'm mainly using ImageMixer that came with my canon as of now.. at least only on those video clips..
I still will use Sony Vegas Pro 8 to do the mov conversions (or sony 9 due out soon)..
Here is a post breaking down some of the tools i've tried (note: there may be an issue with using imagemixer and editing the m2ts file and then porting that to dvd architect, i have to verify this soon):
http://www.avsforum.com/avs-vb/showthread.php?p=14322602#post14322602Check out my Editing thread post located here: http://www.avsforum.com/avs-vb/showthread.php?p=14322602#post14322602
Avoid recompress in DVD Architect
By arcorob in forum Authoring (Blu-ray)Replies: 6Last Post: 29th Apr 2017, 17:59 -
Vegas rendering for DVDArchitect
By hcs in forum Authoring (DVD)Replies: 14Last Post: 13th Nov 2011, 11:07 -
How To Recompress .FLV Video Files
By TonySan in forum Newbie / General discussionsReplies: 1Last Post: 13th Jul 2011, 18:00 -
A Tool for editing AC3 without recompress? (like mp3DirectCut)
By CactusMan in forum Newbie / General discussionsReplies: 0Last Post: 27th Mar 2010, 14:28 -
fast recompress in avidemux?
By Holonet in forum LinuxReplies: 1Last Post: 28th Jan 2008, 11:16
