I'm in Vista.. x64.. on one machine, i found that if i imported any video edited anywhere but imagemixer it would crash (the library).. so i found there, that i could rename the offending file..
This didnt work on my other machine.. now every time i open and click into the library section(browsing and authoring), it doesnt even display the listing just crashes on imxBrowser.exe
I've tried renaming folders in my video folder, that didnt fix it.. I then tried uninstalling and deleting the registry keys.. this didnt help either.. I'm baffled.. at least in Vista i cant see where else the library history is being stored, if this is the problem in this case.
I found that if I went into my codec pack in program files and renamed the Haali folder , then rebooted. Everything started working again. This just makes it so you dont lose your haali stuff and it doesnt start .
(I had image brower working , then it would not work for no particular reason)
For some reason imxbrowser hangs if Haali is active. No idea how it all works.
Godd luck !
How to fix audio sync issue in a wmv file
By pjbarbour in forum AudioReplies: 11Last Post: 20th Nov 2012, 15:29 -
Would a TBC fix this type of issue?
By cfelicio in forum Capturing and VCRReplies: 11Last Post: 7th Sep 2011, 17:53 -
[solved]What is the proper way to fix an ac3 synch issue in a h264 mkv file
By yoda313 in forum AudioReplies: 0Last Post: 16th Apr 2011, 10:46 -
Is it possible to fix a sync issue on a converted file (mp4)
By AndyD in forum AudioReplies: 3Last Post: 23rd May 2009, 22:28 -
How to fix a too bright & too dark issue?
By kinglerch in forum EditingReplies: 5Last Post: 6th Oct 2007, 00:37
