Hi,
I've tried searching through the posts before creating a new post but didn't see anything, so sorry if it's there and I missed it but I'm trying to download and install the mpeg2enc file and whenever I click on the link here and when I searched on Google I kept getting a new window on Safari with text. I have no idea what to do with it.
I tried running ffmpegX without that software and it won't work. It says there is no source video or sound and then it freezes.
I'm pretty new to this. I just want to convert my rm and avi files so that I can upload them into iMovie for editing. Any suggestions?
Cheers,
a. You do not need mpeg2enc for conversions to DV. It is only useful for conversion to mpeg-1/mpeg-2 (VCD/SVCD/DVD). ffmpegX works well without it, when you convert to other formats.
b. The ffmpegX binaries installer doesn't care if Safari or the Finder think mpeg2enc to be a text document. It's okay to use the Locate button to point the installer to mpeg2enc.intel.txt . The installer will figure it out and correct it.
c. For RM source files, you also need to install "reallib" (PowerPC or Intel).
d. ffmpegX cannot convert RM to DV directly, as RM sources require a mencoder preset, and DV target requires a ffmpeg preset. You could convert RM to MP4 and convert that to DV.
Thanks for the help!
I downloaded the RM source your recommended then opened the application and selected .mp4 and finally selected the movie I want to convert and now the program seems to be stuck/frozen: Even though I've clicked "choose" I'm still stuck on the screen though in the background I can hear the computer making those I'm-doing-something kind of noises.
This happened before, too. Any suggestions?
Open ffmpegX, load your Real Media file, then click the [Play] button. The mplayer application should open and play the file. Press [q] to quit. If it doesn't play, then the installation of reallib didn't go right.Originally Posted by cteavin
The correct order is listed at the top of the ffmpegX window:Originally Posted by cteavin
1. Drop file, 2. Select a Target format or use tabs, 3. Encode
Don't switch step 1 and 2. Doing so may alter some settings in unwanted ways.
My copy of ffmpegX has no "Choose" button?Originally Posted by cteavin
Batch "file creation from a text file, Placed into a created directory
By Muther in forum ProgrammingReplies: 5Last Post: 24th Sep 2015, 19:29 -
Output file name ever coming?!?!?
By heffneil in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 17th Nov 2010, 10:02 -
Adding a text logo to a video file without re-saving it to another file?
By coxanhvn in forum EditingReplies: 4Last Post: 19th Dec 2008, 16:03 -
mpeg2enc issue with OSX 10.5 or source file
By ca1amity in forum ffmpegX general discussionReplies: 4Last Post: 10th Jun 2008, 01:48 -
C# code to save text from listbox to a text file -- SOLVED--
By freebird73717 in forum ProgrammingReplies: 2Last Post: 2nd Sep 2007, 16:50
