I own a Sony HC3 HD camcorder since 2006. I never had a chance to watch my recorded tapes in a 1080p LCD TV, but I did so yesterday and the quality is just amazing, what a difference it makes compared to watching them in my PC LCD monitor. The way I watched them was by connecting the camcorder to the 1080p monitor with an HDMI cable. My question is, how can I play those videos in the 1080p LCD without using the camcorder as a player (so to avoid wasting the heads)? I thought about capturing those HD tapes to my PC via firewire, generating HD mpeg files (11gb/hour aprox). And then, how can I burn a DVD-DL with those files so to play them with a regular DVD player with HDMI output.?? What requirements must the DVD player meet in order to be HD compatible? What software is needed to create the DVD? a DL DVD is 9Gb so it won't hold 1 hour of HD video...so should I split the movie? I'm not thinking in BluRay as it is too expensive for now...thanks.
Results 1 to 11 of 11
You can't play them back with a standard DVD player. Standard DVD players are restricted to standard definition resolutions. You need to get a bluray player or if you have an Xbox 360 or PS3, use them as media extenders and player the files that way (you may have to encode them to H264 to do this)
Read my blog here.
I'm in the same boat with my HC5 and have never actually seen the HDV on a TV
waiting until 2010 which will allow a price drop and the consumer software to develope some more, too
hence the sig -
You can do it with a DVI-D to HDMI cable from most display cards. HDMI out just adds part of the HDCP DRM chain needed to play Blu-Ray.Originally Posted by alegator
The video quality depends on the display card deinterlace processing and proper player setup. In general the quality will be less than that direct HDV to HDMI connection from the camcorder but the display cards and PC software players are improving.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
And what about burning the captured HD Mpeg2 to Blu-Ray? I would think that since it involves encoding the captured HD video to the Blu-Ray format, then not even Blu-Ray would reproduce the original 100% quality of playing the video directly from the camcorder (not to mention the time/resources wasted in the encoding).
That depends on the BluRay or media server player. Ideally they would play HDV format directly rather than reformatting for the BluRay standard similar to the way certain DVD players play divx/xvid or MPeg files.
https://www.videohelp.com/hd
People are sorting this out in the threads. You may not need to recode for a certain player, only change the container.Recommends: Kiva.org - Loans that change lives.
What do you mean by "container"?Originally Posted by edDV
Also, I've seen at a friend's house a Sony standard DVD player with HDMI output connector in the back. What's the point of providing an HDMI output if the DVD player is a standard one (not Blu-Ray or HD-DVD)? Thanks -
alegator, in the future please use a more descriptive subject title in your posts to allow others to search for similar topics. I will change yours this time. From our rules:
Thanks,Try to choose a subject that describes your topic.
Please do not use topic subjects like Help me!!! or Problems.
Moderator redwudz -
this is called upconvert:What's the point of providing an HDMI output if the DVD player is a standard one
When connected to your Hi Def TV using the HDMI output the Standard DVD is scaled to HD-compatible size or resolution -
The player will accept certain container formats and not others. MPeg as a transport stream may not be acceptable. A program stream may be. This will depend on what the hardware player accepts beyond normal BluRay encoding.Originally Posted by alegator
A DVD player with HDMI out has an internal upscaler. Alternate is to send 480i or 480p to the HDTV and the TV will upscale. If the HDTV processor is older or cheap crap, the DVD player upscale will be superior. If you have a top line Sony XBR 6, the TV may upscale better.Recommends: Kiva.org - Loans that change lives.
LED MONITOR - HDMI to DVI-D cable, HDMI media player not working?
By krishn in forum DVB / IPTVReplies: 16Last Post: 25th Feb 2012, 17:20 -
Can I connect camera HDMI to camcorder HDMI?
By Darryl In Canada in forum Newbie / General discussionsReplies: 6Last Post: 15th Jan 2012, 17:06 -
Which is better? [1080p Monitor comparison]
By Engineering in forum ComputerReplies: 5Last Post: 17th Dec 2009, 08:00 -
multimedia player connection via hdmi but monitor doesnt have hdmi slot
By ozy666 in forum DVB / IPTVReplies: 1Last Post: 25th Apr 2009, 10:40 -
dvd player hdmi to computer monitor with hdmi
By Kibble in forum DVD & Blu-ray PlayersReplies: 5Last Post: 10th Nov 2008, 13:35
