Greetings.
I have large MP4 files which I need to edit before archiving to DVD. I have the Womble MPEG2VCR and also the Womble Video Editor but they dont seem to to work for MP4.
Any advice?
Regards.
What kind of MP4? That's just a generic container name and says little about the actual codecs used. But try VirtualDub. It works with most AVI type formats. You can also tell what codec your file is using with Gspot or MediaInfo.
Most highly compressed formats, MP4 variants included, are difficult to edit. Xvid, for example, has a keyframe spacing of 300 frames by default. This makes frame accurate editing very difficult unless you want to re-encode the whole file and have the quality loss. The newest VD can let you cut almost anywhere in the video, then will just re-encode at the cut points. Look for 'Smart Rendering'.
Generally, you want to avoid editing with highly compressed formats. Better to edit the video in the native format, then encode to the final format for viewing.
Thanks a lot for your help.
I will try the above software and also get more information about my mp4 files.
Regards.
Can't edit MP4 files in Virtual Dub
By brevardo in forum EditingReplies: 25Last Post: 10th Mar 2011, 20:18 -
Edit MP4 Files
By Tylerr in forum EditingReplies: 10Last Post: 4th Feb 2011, 15:23 -
Software to edit MP4 (H.264) files from my camera
By Gionames in forum EditingReplies: 3Last Post: 13th Dec 2010, 23:20 -
How to edit mp4 files and play them on my PS3?
By FlipUser in forum Video ConversionReplies: 3Last Post: 21st Oct 2009, 17:25 -
HOW TO EDIT MPEG4 FILES IN (DIVX).AVI, .mkv and .mp4 Containers
By jhb50 in forum User guidesReplies: 0Last Post: 18th Jul 2009, 22:32
