I'm in need of some expert advice on video conversion. I have some video that has been stored in a "progressive scan" format in a MPEG-4 AVI file. The problem is that the person who created the file de-interlaced the fields in the wrong order, so there is a tremendous amount of "tearing" in any motion in the video. Is there an easy way of correcting to filed order.
I use Ubuntu Linux and AVIDemux on my main machine, so if there is a solution for that platform that would be easiest for me. But, I have a Windows XP laptop and can install any tools necessary on there.
Thanks.
Brian
sample
"I'll give you five dollars if you let me throw a rock at you"
Lower field first/upper field first/progressive/de-interlaced?
By John Nada in forum EditingReplies: 7Last Post: 2nd Sep 2011, 04:12 -
Need info on field order for capturing mpeg video
By snafubaby in forum Capturing and VCRReplies: 3Last Post: 22nd Dec 2010, 08:58 -
Field Order
By Tafflad in forum Authoring (DVD)Replies: 9Last Post: 30th Jan 2010, 01:38 -
Problem with field order on captured video
By brassplyer in forum EditingReplies: 8Last Post: 3rd Apr 2009, 07:06 -
Swapping the Audio Streams in a MKV in order to then convert
By JP585 in forum Video ConversionReplies: 2Last Post: 22nd Dec 2008, 05:26
