klintistwood
use eac3to version 2.00 for your vc1 file if you just extract the vc1 file it won't play but if you use eac3togui to demux plus strip the pulldown then it will play if you use my settings in the xvid4psp you get a file at around 4 gigs then when you add the audio it will be about 4.6 gigs. also use the mp4ps3 option don't worry it will still be playable on your computer
as for the mkv thing in eac3togui thing waht ever the last thing is take it off and add .mkv.
so if your file is like transformers .vc1 just take off the vc1 and make it .mkv
Results 31 to 43 of 43
zerocool, the conversion with eac3to worked but the result is strange, the picture gets pixels all over the place. Is there an option I could use to avoid this?
I've tried to convert the first movie to mp4 like you said but when playing it with sound, I have once again a sync problem, it's not as strong as when I muxed my first MKV but still, there is a sync problem
now as for movie 1 did you use the mp4ps3 option also which media player are you using the best one is media player classic and vlc but vlc sometimes throws it out of sync when watching on a computer. try watching it on your tv if possible.
as for your second question for the second movie try to encode it and see what happens just because it's blocky doesn't mean your mp4 will turn out that way -
This is what I would try on,
Movie1
Demux M2TS file with tsmuxer> .mpv and DTS audio
Convert DTS audio to ac3 with eac3to.
Remux .mpv and new ac3 to .m2ts file with TSmuxer and use the split&cut feature ,if you want several files,5-6gig etc..
Check with VLC for sync issues....
Now load new.m2ts file in XviD4PSP.." Who needs Google, my wife knows everything" -
Hi zerocoool
I had use mplayer classic to play the video with the sound and in fact I noticed that the delay in ms for the sound was variable. I'm going to try to force a 0 delay in the settings and see if it solves the problem. The sound sync problem is by far less important than my first try with MKV as output.
I'll try the remux suggestion you are both proposing, we'll see if it solves the sound problem.
Thanks! -
t0nee1:
I have tried what you suggested and after muxing everything back to M2TS, the sound was perfectly synchronized with image. So I took the M2TS in XVID4PSP and converted it to MKV and got again the sync problem.
In fact I only get the sync problem when I randomly pick a sequence ahead of the cursor, if I play everything from the beginning and let it go this way, I don't get sync problems. It looks like it's a player related problem no?
I usually get rid of the sync problem by pausing then playing again. -
What SW player are you using? I use VLC or MPC...maybe try with, CyberLink PowerDVD Ultra.
With my specs I have the same issues playing certain HD content from PC..However I don't play my video from PC,but stream or burn to disc for playback on my PS3......I typically keep as .m2ts file, change extension to .mpg or .vob and burn..Or sometimes I'll create a Bluray structured disc...
I'll only use XviD4PSP if I want to convert to other formats and reduce the size of my video..." Who needs Google, my wife knows everything" -
I tried to play the movies with VLC and MPC.
With MPC I usually manage to get back the sound on track by pausing and the playing again. It's a very strange behaviour especially if you know that sound and video are part of the same file. If I play the movie without moving forward, I don't get any sync problem but if I start jumping around, then I get sync problems. -
Try installing MeGui as well as XVID4PSP because doing so should also get you all the other software and codecs etc. needed to play back most if not all MKV files.Originally Posted by atwozed
Also make sure you have the latest version of VLC media player.
I've been following this conversation today (googled Blu-ray burning to file). I was also coincidentally curious in creating .mkv files from Blu-Ray.
If I may temporarily interrupt (although I am rooting on the sidelines for the success of Mr. Wood in this story) I was curious as to what you would define as "quite adequate" specs for a PC to burn Blu-Rays as .mkv equivilents and then play them? Not necessarily to play the Blu-Rays from the drive. For example, an intel core 2 duo 2.0ghz as a processor, 2 gig dual channel (667mhz) and either a GMA X3100 or 950 be adequate? Do you have suggestions for such specifications for this purpose?
Secondly, what method would you use to get a perfect balance between file quality and size? For example, what size would an .mkv created, at your own discretion to form be? Is there a format that you would prefer/suggest over .mkv for seeking a modest file size with maximum quality?
Thanks, and again, sorry for interrupting.
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19 -
Can i burn avi/mp4/mkv etc to blu ray media and play it in a blu ray player
By brad350 in forum Newbie / General discussionsReplies: 10Last Post: 21st Apr 2012, 05:15 -
Blu-ray converted to .mkv now i want it back to blu-ray structur ?? help
By Trigarr in forum Authoring (Blu-ray)Replies: 8Last Post: 20th Oct 2011, 13:34 -
Multiavchd..Need Help..MKV-BLU RAY-- Freezing on Blu Ray Menu!!
By Thuglas in forum Authoring (Blu-ray)Replies: 1Last Post: 14th Sep 2010, 23:58
