I've started converting a bunch of old 8MM video I took so we can watch it on the computer. I was thinking of using .mp4. Ideally whatever format I go with will be supported for a long time in future software. Are there better formats to consider?
I'd say DVD MPeg2 is better. Widely supported and easier to edit. Better still is DV format.Originally Posted by zapsterRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
I'm doing the conversion myself and it comes in as DV. Then I dump to DVD. But, I also want to convert a bunch to a smaller size just for PC playback. Ideally I can keep close to the DVD quality but with a much smaller foot print.
Currently considering:
mp4
wmv
dvix
xvid
I'd really like something that plays easily on other PCs/Macs and will still be supported in 10 years (I know, a tall order). -
Wmv/VC-1 and h.264 will have long term universal support.
Today's divx/xvid may or may not be supported long term since these evolve outside international standards.Recommends: Kiva.org - Loans that change lives.
Convert to MP4 format
By dvrvarma in forum Portable VideoReplies: 7Last Post: 7th Mar 2014, 12:09 -
DVD format: Okay to do it in MP4?
By 00glitch in forum Authoring (DVD)Replies: 8Last Post: 30th Nov 2011, 00:00 -
MKV or MP4? Which format should I use?
By WPlotkin in forum Newbie / General discussionsReplies: 6Last Post: 29th Oct 2009, 19:06 -
Converting from Flash .flv format to iPod Compatible .mp4 format in ffmpegX
By bananasontoast in forum ffmpegX general discussionReplies: 1Last Post: 3rd Jan 2009, 09:15 -
What format, DVD, mp4, this that what?
By overloaded_ide in forum DVD RippingReplies: 1Last Post: 15th Jun 2007, 19:43
