I lost six DVDs + DL 8.5 GB trying to record with Asus 2014 sata driver video already ripped to HD with DVD FAB Decrypter and using Nero Recode last version 3140 from Nero8 Pack.
At final stage recording making lead out Nero says :
Burning Process failled at 8x
Could not perform end of Disc at once
Power calibration area error
The disc is not finalized is open and plays perfect on PC but not at DVD Player
If I record same video at same Writer on a DVD +- R 4.7 GB everything is OK the disc is closed at lead out and Plays well on PC or DVD Player
Same occurs if I use IMG BURN instead of Nero Recode
What is happening ?
Could be a Writer or soft fault ?
Thanks in advance!!
Results 1 to 9 of 9
What brand DVD+R DL discs? We recommend ONLY Verbatim DVD+R DL discs. Using other brands is often a problem. However, if I remember correctly the infamous "power calibration" error might be fixed by upgrading your firmware, so definitely do that AND use only Verbatim DVD+R DL discs AND only burn with ImgBurn.
Your problem is the use of low grade DVD+R DUAL LAYER media. As mentioned use only VERBATIM DVD+R DUAL LAYER media or have a spindle full of coasters with those PHILIPS & RICOH DL media.
I cant get Verbatin Dual
It is unavailable here
I just got these post on another forum
luifer
VIP Member
Tech Points : 0
Level : Level 1
Posted:6/10/2008 11:36:00 PM
Hello !
I bought recently a new pc with one of this drives. Been using it with no problems to read, etc. When i'm going to burn, nero displays the error "power calibration failure"... also tried with alcohol 120%, but this app gives no error message, it only crashes.
I was able to "burn" something after using "auto detect speed" + "simulate" + "write", but when instaling the program i burned, it just froze at 80% of installation...
I've been able to burn some data discs so far though, and aparently they work fine, but this power calibration failure thing... sigh...
can anyone help me? plz !
This is the nero log :
user
1K22-0867-0795-66M4-5048-7289-****
Windows XP 6.0
IA32
skvwire
VIP Member
Tech Points : 0
Level : Level 1
Posted:6/19/2008 12:01:00 PM
WOW...something very similar just happened to me! Same failure. I was trying to burn an image on a dual layer disc. hmmm.....
Edit Reply Quote & Reply
AMD Phenom 9500, ASUS Triton 70, ASUS M2N32-SLI Deluxe Wireless Edition, BFG 8800 GTS EE OC 640, NZXT Lexa Blackline, Patriot Extreme Performance 4GB DDR2 PC26400, Windows XP Pro SP3, 1 Tb HD space (3 HD's), Avid Express Pro HD, Acid Pro, Abletone Live, Photoshop CS2 blah blah blah... -
fjmr - I told you something you could do in my post that might solve this problem and it did not involve buying Verbatim discs, although you are really wasting your money trying to burn to Ricoh and Philips discs.
jman98 Thanks if I could I would buy Verbatin DL
As I said before my firmware is 1.02 and as far I know it is the last one
So I am still in Trouble and waiting for a solution! -
OK OK Victory
I am Happy again
I am Happy again
Here is the solution
Open Nero 8 start smart and toolbox
Look for NeroDiscSpeed and then Extra and finally Bit Setting
Bit Setting click on DVD ROM for all
That is the Trick!!!! -
Now complete victory.
The problem cameback but I could solve it finally.
It was a power laser related problem.
My OS Vista was setup for energy economy so there was not enough power for the laser.
I changed that for full perform instead and that did the Trick!!!
:P :P :P
Converting DVD to DVD with sub-titles fails
By bowlerboy in forum ffmpegX general discussionReplies: 4Last Post: 16th Oct 2011, 21:55 -
HELP with Roadstar DVD 2014-H
By bigbenjo in forum DVD & Blu-ray PlayersReplies: 3Last Post: 14th May 2010, 09:32 -
Burn fails while burning DVD video not data dvd
By cd090580 in forum Newbie / General discussionsReplies: 2Last Post: 8th Feb 2009, 02:27 -
DVD shrink fails to rip home recorded dvd in multiple sessions
By sybariten in forum Authoring (DVD)Replies: 9Last Post: 21st Aug 2007, 22:42 -
All of a sudden every DVD fails
By skeeveman in forum Newbie / General discussionsReplies: 13Last Post: 15th Jun 2007, 09:50
