I have IDX and SUB files. So how can I convert it to SRT?
Results 1 to 13 of 13
In the subtitles forum there is a sticky:
https://forum.videohelp.com/topic267416.html -
If you don't have the orignal VOBs, good luck. I've never been able to convert SUB/IDX files without them, but perhaps you will be one of the rare people who actually is able to do this. I'm not saying it's impossible, I'm just warning you that my experience has been 100% negative in trying to do this without the original VOBs.
An easy alternative is to find your subs on a database (e.g. opensubtitles.org, many others), free download. They have hundred's of thousands in multiple languages
'SubtitleCreator ' => Tools => Translate Sup or VOBSub to SRT
If it's a .sup file it needs an IFO reference, but any ifo can be used. -
i used this method to create a .srt file from .idx file ... i translated some of it about 35% , and i accidentally closed it ... !
how to open that first translated part (.srt file ) and continue translation on it without losing the previously saved text ???
each time i open it , it says loaded ,but i see empty srt file ,and when saved , all old text is cleared !!
any help with that please ?? -
Originally Posted by momoaal
Have a look at a few normal SRTs and you will soon understand the format, and hopefully work out what's wrong with yours.
SEQUENCE NUMBER (Starting with 1)
START TIME --> END TIME
Text, text text.
Example:Code:1 00:00:20,120 --> 00:00:21,320 What?! 2 00:00:23,440 --> 00:00:24,440 WHAT?! 3 00:00:31,600 --> 00:00:32,640 What? 4 00:01:43,880 --> 00:01:45,880 Ri-i-i-ght... 5 00:01:46,920 --> 00:01:48,520 'Attention all passengers.
thanks AlanHK , but this is not my problem ...
i simply use the Sup to srt tool ...
i start conversion/ translation ... and after some time like 35 % of the file
i saved it ..
i want to continue the translation from idx to srt , from the last position i stopped at .. last time ...
but subtitle creator is just creating a new file .... !! and clear all old text !
i just want to continue the translation process ! with the rest of the file .. -
i guess that is it -> Forum Index -> Video -> Subtitle !! right ?
so i think i'm in the right place !
or there is some other subtitle forum !??
anyway , if moved plz give me the new address so i can trace replies ...
thanks ... -
Any replies would be in this forum. When moving a thread, a link is left in the original forum for a few days so others can easily find the posts.
redwudz
Convert .sub, .idx to .srt subtitles?
By Ryu69 in forum Video ConversionReplies: 17Last Post: 9th Jul 2011, 04:23 -
.SRT (text) to .SUB/.IDX (image) subs
By Sheavi in forum SubtitleReplies: 7Last Post: 29th Dec 2009, 03:42 -
converting sub/idx to srt
By scarlac in forum DVD RippingReplies: 3Last Post: 9th Dec 2009, 07:26 -
How can Icreate 1 idx/sub with several srt?
By moryjingelbert in forum SubtitleReplies: 1Last Post: 15th Feb 2009, 14:42 -
Converting sub and idx subs into srt
By peyem in forum SubtitleReplies: 1Last Post: 4th Apr 2008, 18:23
